Thread Number: 67742
Maytag A606 (300227DW) Knock/Tick Tock while Agitating |
Post# 904611 , Reply# 1   10/28/2016 at 17:40 (2,730 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 904654 , Reply# 5   10/29/2016 at 06:29 (2,729 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 904661 , Reply# 6   10/29/2016 at 07:48 (2,729 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I would also just keep using this washer if it appears that the noise is in the transmission, the noise may not hurt anything for years and fixing it now will will be the same as fixing it later. It might be best to grab another MT washer for a spare transmission if you want to keep this washer going another many years.
[ The nylon pinion gear will not cause a knocking noise, the steel agitation output gear could if it is coming loose, the noise could be an agitator that is loose on the shaft, but if that was the case the agitator would likley pull off easily ] |
