Thread Number: 67791
Possibly apart of an old GE filter-flo washer? |
Post# 905097 , Reply# 1   11/1/2016 at 18:46 (2,729 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 905101 , Reply# 2   11/1/2016 at 19:03 (2,729 days old) by KenmoreWasher72 (US)   |   | |
Okay cool, thanks for the info! |
Post# 905103 , Reply# 3   11/1/2016 at 19:07 (2,729 days old) by Ottoreese (Indianapolis, Indiana )   |   | |
Is that an unused ff, Unimatic?? |
Post# 905172 , Reply# 5   11/2/2016 at 12:23 (2,728 days old) by bajaespuma (Connecticut)   |   | |
Post# 905189 , Reply# 6   11/2/2016 at 14:49 (2,728 days old) by KenmoreWasher72 (US)   |   | |
Oh okay, thanks Washdaddy. |
Post# 905192 , Reply# 7   11/2/2016 at 15:55 (2,728 days old) by Yogitunes (New Jersey)   |   | |
that is a bit puzzling, as I have seen clothing get stuck in a pump....
how exactly did it get there?.....of all the years of having filter-flos, have yet for anything to 'spin-out' over top, as caused by the machine.... just willing to bet its more of mainly while un-loading, clothing pulled out in clumps, that a sock or similar item, get dragged across/under the tub ring, and fall behind the tub... has anyone ever seen this actually happen by the machine?.....I would have expected to see more of this type of thing with a solid tub, as clothing would actually be pushed up against the tub ring.....most loads in a filterflo, or even a Maytag, are plastered under the balance ring, rarely would you ever see a piece go further up!.... I have seen one machine that would forever have a tube sock wrap under the agitator for one lady, I ran load after load, nothing would turn up wrong....she would run the next load, and theres that stuck sock again..... |
Post# 905201 , Reply# 8   11/2/2016 at 17:28 (2,728 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 905202 , Reply# 9   11/2/2016 at 17:36 (2,728 days old) by ken (NYS)   |   | |
is what I found in the pump of the 83 FF I got a couple years ago. Worked fine after removing it.
Post# 905380 , Reply# 11   11/3/2016 at 22:59 (2,727 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
