Thread Number: 67825
Thumping sound from 1979 DE808 Maytag dryer |
Post# 905378 , Reply# 1   11/3/2016 at 22:57 (2,723 days old) by alr2903 (TN)   |   | |
No expert, but most likely the drum rollers or glides whatever your dryer has. We once had a Magic Chef dryer that would play a tune. In our case after the second set of rear rollers failed we moved on to something else. |
Post# 905410 , Reply# 2   11/4/2016 at 07:27 (2,723 days old) by vacerator (Macomb, Michigan)   |   | |
drum rollers, an idler pulley, and a new belt wouldn't hurt either. Those Maytags have no glides. GE's have nylon glides at the front shroud. |
Post# 905427 , Reply# 3   11/4/2016 at 09:28 (2,723 days old) by Floyde (Los Angeles, CA)   |   | |
Are this parts Still available? If I Call a repairman could they Do this repair and get the parts? I'm not The least bit handy! Thank you! |
Post# 905439 , Reply# 4   11/4/2016 at 10:18 (2,723 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It's most likely a rear roller, the idler pulley would make a screeching her high-pitched rattling noise if it were bad, this dryer does have front slides they don't usually make up bumping noise and less they are completely shot.
The blowers are also a big problem on these dryers they tend to come loose on the motor shaft although they don't usually make up bumping noise. It should still be fairly easy to get this dryer repaired just be sure you tell them how old it is and make sure the company you select is willing to work on it |
Post# 905505 , Reply# 6   11/4/2016 at 19:44 (2,722 days old) by goatfarmer (South Bend, home of Champions)   |   | |
