Thread Number: 67939
POD 11/11/2016 |
Post# 906476 , Reply# 1   11/11/2016 at 05:37 (2,715 days old) by appnut (TX)   |   | |
Post# 906478 , Reply# 2   11/11/2016 at 06:43 (2,715 days old) by Yogitunes (New Jersey)   |   | |
Post# 906481 , Reply# 3   11/11/2016 at 07:04 (2,715 days old) by vacerator (Macomb, Michigan)   |   | |
as well. They were very well made, but some did require servicing because families were larger then still, and overloading could be hard on their belts, clutches, motors and spin tubes. Little items too, like the occasional mix valve, timer, and solenoids. |
Post# 906496 , Reply# 4   11/11/2016 at 08:28 (2,715 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 906550 , Reply# 5   11/11/2016 at 15:41 (2,715 days old) by cycla-fabric (New Jersey (Northern))   |   | |
This is my Sears Kenmore 800 a 1973 model that runs very well.
Doug
Post# 906575 , Reply# 6   11/11/2016 at 18:54 (2,715 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The ONLY thing overloading these sturdy washers could is cause is a belt failure, overloading had NO effect the motor, clutch, spin tube etc.
Overloading as with most washers actually makes them last LONGER as you are doing less total loads, do bear in mind that the laundry results are better and clothes look better and last longer if you put the correct amount of clothing in the washer. |
Post# 906579 , Reply# 7   11/11/2016 at 19:27 (2,715 days old) by mrclean87 (Southcentral, Pennsylvania)   |   | |
This was the exact washer my grandmother had--it was the first automatic washer she purchased along with the matching dryer. The bright console light lit up the corner of the basement where the washer and dryer were located. Many memories of doing laundry in that machine when I was a teen. |
Post# 906942 , Reply# 9   11/14/2016 at 13:59 (2,712 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
