Thread Number: 67987
/ Tag: Vintage Dishwashers
Kitchen Aid KDP 20 Push Button Switch |
Post# 906944   11/14/2016 at 14:20 (2,716 days old) by brucewiebe (Stillwater, MN)   |   | |
Hi, My pushbuttons don't work anymore. Any ideas on getting a new or refurbed switch? Don't want to spend on a new and flimsy machine. Best Bruce |
Post# 907015 , Reply# 1   11/15/2016 at 01:22 (2,716 days old) by stevet (West Melbourne, FL)   |   | |
There are some numbers printed on the back of the program switch. If you let me know what they are, I probably have a switch for you! Steve |
Post# 907045 , Reply# 2   11/15/2016 at 07:22 (2,715 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Or is the switch bad electrically ?
If the buttons are getting stuck spray electrical-safe lubricant into every crack and crevice of the switch and then work the buttons until the switch loosens up. These switches used to get balky because users only ever used one cycle all the time [ usually normal ] and the switch would get a little worn. |
Post# 907053 , Reply# 3   11/15/2016 at 08:00 (2,715 days old) by brucewiebe (Stillwater, MN)   |   | |
The numbers are: L1 D241510 on left end of switch On right end the numbers are 2998AF 72 3983 M I'll try spraying the switches elec safe lubricant as you advise Combo52. I'd wondered about that. Have to get some lube. Is WD 40 safe? |
Post# 907074 , Reply# 4   11/15/2016 at 10:36 (2,715 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
