Thread Number: 68125
May tag A207 shakes |
Post# 908503 , Reply# 1   11/25/2016 at 23:24 (2,701 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You will not need new springs.
You also do not need the brake removal to remove the brake assembly, just take a vice-grip pliers and clamp it on the edge and hit it with a hammer, this works much better than the silly brake tool.
However you may need to replace the aluminum damper if the damper pads are completely gone and the polished aluminum surface has gotten scored and rough.
Post# 908519 , Reply# 2   11/26/2016 at 02:27 (2,701 days old) by Sbond22 (Grove City, Fl. USA)   |   | |
Post# 908693 , Reply# 3   11/27/2016 at 10:25 (2,700 days old) by s2vrl (massachusetts)   |   | |
the springs do look sturdy. I will disassemble to check/change damper pads. Where do you suggest I look for an aluminum damper, if this needs replacement? I may post photo of innards once I disassemble. thanks |
Post# 908794 , Reply# 4   11/27/2016 at 23:51 (2,699 days old) by askolover (South of Nash Vegas, TN)   |   | |
from Red Carpet Drew
www.automaticwasher.org/cgi-bin/T... as well as the one below from a few years ago. CLICK HERE TO GO TO askolover's LINK |
Post# 908958 , Reply# 5   11/29/2016 at 06:00 (2,698 days old) by s2vrl (massachusetts)   |   | |
these links are very helpful. Many thanks. |
Post# 913670 , Reply# 7   1/2/2017 at 17:24 (2,663 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 914040 , Reply# 8   1/4/2017 at 22:40 (2,661 days old) by Dustin92 (Jackson, MI)   |   | |
Make sure you get GENUINE Maytag belts, off branded belts won't work well, definitely worth the few extra $. |
Post# 914145 , Reply# 9   1/5/2017 at 16:29 (2,660 days old) by eronie (Flushing Michigan)   |   | |
Clutching drive belts work for me. |
