Thread Number: 68153
/ Tag: Twin-Tub Washers
Hoovermatic 3314L |
Post# 908730 , Reply# 1   11/27/2016 at 15:10 (2,705 days old) by triumphdolomite (Staffs(UK))   |   | |
Post# 908731 , Reply# 2   11/27/2016 at 15:11 (2,705 days old) by triumphdolomite (Staffs(UK))   |   | |
Post# 908732 , Reply# 3   11/27/2016 at 15:12 (2,705 days old) by triumphdolomite (Staffs(UK))   |   | |
Post# 909254 , Reply# 5   12/1/2016 at 14:26 (2,701 days old) by Ricky5050 (Durham Britain)   |   | |
Hi Ian !! No problem glad to be if assistance! It looks a lot better than it did and I bet it smells better too ! It looks right at home in your kitchen! I have no idea on what goes where with rinse pipe thing I leave that to the experts. What is all that hairy stuff ? The belt ? Was it that bad ? Lol
Good luck Richard |
Post# 909963 , Reply# 7   12/6/2016 at 20:00 (2,696 days old) by Bobbi (Pennsylvania)   |   | |
It looks gorgeous! |
Post# 910034 , Reply# 8   12/7/2016 at 14:27 (2,695 days old) by triumphdolomite (Staffs(UK))   |   | |
It looks a lot better now. Should be up and running before long, just need to sort a couple of hoses out. Ian |
Post# 910097 , Reply# 9   12/8/2016 at 01:17 (2,694 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Post# 910106 , Reply# 10   12/8/2016 at 04:14 (2,694 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 910125 , Reply# 11   12/8/2016 at 08:35 (2,694 days old) by Slowspin66 (lincoln uk)   |   | |
Post# 910184 , Reply# 13   12/8/2016 at 16:09 (2,694 days old) by Sesteve (London, UK)   |   | |
Wow Ian
Looks great compared to when I last saw it. I'm still amazed how well it all worked given its state. On the filler hose I've attached a picture from the service manual - I'm not 100% sure but I think the end of the hose connects to the plastic spigot on the can with the larger clip and the tube is pushed into the hose so it's flush with the wash deck and secured with the lower smaller clip. That allows you to pull off the nozzle but leave the tube in situ. You are after the hose with the pressure switch aren't you? I have some spare bits so I can send you one if you email me your address Cheers Steve |
Post# 910186 , Reply# 14   12/8/2016 at 16:21 (2,694 days old) by triumphdolomite (Staffs(UK))   |   | |
Cheers Steve, I'll drop you a line Thanks Ian |
