Thread Number: 68213
POD 12/03/2016 |
Post# 909474 , Reply# 1   12/3/2016 at 10:36 (2,694 days old) by Helicaldrive (St. Louis)   |   | |
This MW pair? |
Post# 909475 , Reply# 2   12/3/2016 at 10:46 (2,694 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 909486 , Reply# 3   12/3/2016 at 12:20 (2,694 days old) by Helicaldrive (St. Louis)   |   | |
DUH. Thanks |
Post# 909487 , Reply# 4   12/3/2016 at 12:29 (2,694 days old) by alr2903 (TN)   |   | |
The were visually striking on the showroom floor. |
Post# 909534 , Reply# 5   12/3/2016 at 23:10 (2,693 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I remember the showroom at our MW store full of these Signature sets. They had a set with clear cabinet top, front and sides so you could see the huge fan at the back of the dryer drum and the solid construction of the washer. They also had a Westinghouse built front-load stacked set loaded with white towels and running to show the thorough tumbling action.
Post# 909574 , Reply# 7   12/4/2016 at 10:18 (2,693 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
No washer maker ever called there tub capacity 13#s, especially Norge who always lived under a cloud of poor reliability, 13 would have been just too unlucky, LOL.
You are somewhat correct, the same size tub started out life as a 15# washer and went to 16, 18 and finally 20 # capacity with a 3/4 HP motor to turn over 20 pounds of clothing, I never saw a 22# model. |
Post# 909583 , Reply# 8   12/4/2016 at 11:56 (2,693 days old) by appnut (TX)   |   | |
Post# 909603 , Reply# 9   12/4/2016 at 15:07 (2,693 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 909656 , Reply# 10   12/4/2016 at 20:02 (2,693 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Bob, you could be partly correct, but I was referring to Norge style washers that still had the same steel wash basket they started using in 1964 through the early 80s.
Once MT redesigned these machines somewhat they used a plastic inner and outer tub and these may actually have been bigger than the orignal steel tubs, so I am not sure it is accurate to say they just relabeled the same tub as a larger capacity. I also think there was never a washer labeled Norge with a 22 # capacity. |
Post# 909685 , Reply# 11   12/5/2016 at 01:57 (2,692 days old) by tolivac (greenville nc)   |   | |
Sounds like Norge was sizing their washers after some old time artillery piece sizing-the size shell the gun fired. |
