Thread Number: 68305
Calling all Frigidaire experts |
Post# 910544 , Reply# 1   12/10/2016 at 19:12 (2,665 days old) by brucelucenta ()   |   | |
It really depends on what vintage you are talking about. |
Post# 910551 , Reply# 2   12/10/2016 at 20:00 (2,665 days old) by phmorrow (Knoxville, TN)   |   | |
I believe the machine is a 65' deluxe model non rapidry. the other machine I mentioned with the bearings is a 68' WIN model Imperial with the rapidry feature. |
Post# 910613 , Reply# 6   12/11/2016 at 09:04 (2,664 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
can just be tapped out with a bearing punch once the mechanism is completely torn down. The rollermatics have a very bizarre lower bearing it has a key pressed into it and if I recall the lower bearing is actually a metric size unlike the upper bearing. So you have to tap out the key and insert it into the new bearing.
Tricky but doable.
Post# 910623 , Reply# 7   12/11/2016 at 10:25 (2,664 days old) by PhilR (Quebec Canada)   |   | |
The lower bearing is an odd one, I think it's metric on the outside but not the inside diameter. I wanted to replace
It in my 1965 Roller-Matic but I couldn't find one! I did replace the top one and it fixed the loud spin noise. I also had to remove hair (mine!) around the water pump seal once on that machine because it caused a leak. The seal itself was OK. |
Post# 910850 , Reply# 8   12/12/2016 at 21:18 (2,663 days old) by joelippard (Hickory)   |   | |
Check this thread out where I did a complete teardown and replacement of the lower bearing. You may find some helpful information in there. Ben did a lot of research to help me at the time.
Joe
CLICK HERE TO GO TO joelippard's LINK |
