I've had this for a couple of years, first sitting in my garage, then hauled down the basement. I was intending to use it today but the weather stopped me. More on that later...
Anyway it has not been used in decades as far as I know. It came out of a one owner house, and the owner did not like to use the unit. It appears to have been used a bit in the past from the wear on the interior. Everything seems to work, I did note a small trickle of water after the valve closed, the seal may be dried out. It did seem to stop. The racks are in very good shape too, a plus.
My main question is is there a way to lube the bearings? The motor sounds a bit noisy, a little whine. The housing of the motor show a moderate amount of rust, though I did not see any evidence of a bad seal, no water under the machine.
I had intended to run the glass from my exterior lights through the machine since it has a very good flow of water, I usually use the Whirlpool in the basement but occasionally I did see some residue remaining on the glass even with the force it has. But we got close to 12" of snow the other day and it's a bit hard to get to some of the lights, have to wait a bit as it now will been in the single digits for the next few days. Hate to decorate lights that are not sparking clean.
Any way have the original tag from Hobart on the machine --
Model 11 Stainless steel
Serial number - 377044
Motor watts - 320
Heater watts 1000
Inspected by ( hard to make out the sig...) Kipner (?) Riotac (?) no.232539
