Thread Number: 68367
/ Tag: Vintage Dishwashers
Insinkerator model 3000-2 |
Post# 911107 , Reply# 1   12/14/2016 at 11:08 (2,688 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 911132 , Reply# 2   12/14/2016 at 13:12 (2,688 days old) by rp2813 (Sannazay)   |   | |
I've owned an Insinkerator dishwasher, but am not familiar with the model number 3000-2.
As John stated above, ISE dishwashers are KitchenAid clones. If you can post a picture of the interior and exterior, it should give an indication of which KitchenAid models are equivalent. Once that is determined, you'll probably have better luck searching for a KitchenAid part instead of using the obscure ISE as a search term. |
Post# 911148 , Reply# 3   12/14/2016 at 15:22 (2,688 days old) by Met1 (Hickory NC)   |   | |
Thanks so much. The best I can figure is like you guys say it is a KA knockoff and I think equivalent to the 22 series. Here are a few pics with it apart and the seal. The motor has Kitchenaid on it. Thanks again for any help. |
Post# 911155 , Reply# 4   12/14/2016 at 16:30 (2,688 days old) by rp2813 (Sannazay)   |   | |
On the outside, it looks like the white-on-white version of my black-on-black ISE Classic Supreme, a KA 22 series clone.
I can't say for sure, but based on photo #1 your machine might be a 23 series KA clone, which is significantly different (in a good way) from the 22. John (combo52) can confirm one way or the other. |
Post# 911156 , Reply# 5   12/14/2016 at 16:41 (2,688 days old) by Met1 (Hickory NC)   |   | |
Thanks so much. I have read in some old posts that the handle design was a little different on the earlier classic series. I know mine was right at the end of the ise "agreement" circa 1994. Think it was right before they all went to cheaper units. |
Post# 911173 , Reply# 6   12/14/2016 at 18:59 (2,687 days old) by stevet (West Melbourne, FL)   |   | |
So all the pump parts from the 23 series will be the same as this unit. Most of the mechanical parts are the same as well. However, timers and such may differ from the actual KA parts in the 23 series. |
Post# 911175 , Reply# 7   12/14/2016 at 19:45 (2,687 days old) by Met1 (Hickory NC)   |   | |
Thanks again. Will try searching for those part numbers then. Any particular model number better than another to search? |
Post# 911190 , Reply# 8   12/14/2016 at 22:48 (2,687 days old) by rp2813 (Sannazay)   |   | |
Probably KUDS23, KDS23, KUDI23 or KDI23 would work. That particular part would be the same across the model line.
The different latch/handle assembly on ISE models was part of the agreement that allowed ISE to market their KA clones. Otherwise, it was felt that they'd appear identical to KitchenAids, and at a lower price point would cause KA to lose too much market share. |
Post# 911207 , Reply# 9   12/15/2016 at 07:29 (2,687 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 912696 , Reply# 12   12/26/2016 at 22:35 (2,675 days old) by jkbff (Happy Rock, ND)   |   | |
