Thread Number: 71300
/ Tag: Detergents and Additives
STPP for the washer |
Post# 943653   6/15/2017 at 21:37 (2,505 days old) by JesseD (Saint Marys, Pennsylvania)   |   | |
I have been reading some older discussions about adding STPP to laundry detergent to make up for the missing phosphates. I was wondering how well it helps and where I could get some and also how it affects the clothes. |
Post# 943664 , Reply# 1   6/15/2017 at 22:31 (2,505 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 943666 , Reply# 2   6/15/2017 at 22:35 (2,505 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 943668 , Reply# 3   6/15/2017 at 22:39 (2,505 days old) by JesseD (Saint Marys, Pennsylvania)   |   | |
I use Tide powder original or mountain spring. |
Post# 943685 , Reply# 4   6/16/2017 at 00:35 (2,505 days old) by sudsmaster (SF Bay Area, California)   |   | |
The latest Tide powder is pretty good stuff. Unless you are not getting various stains, esp stuff like ground in garden dirt, out of clothing, you might not need STPP added. And, I'm a big fan of STPP, but have found the Tide powder I bought in the last year or two works well enough without it. Thus I haven't yet resorted to amending the powder with STPP. However in the past I've amended another powder, Sears Ultra Plus HE, with about 30% by weight STPP. That worked fairly well, but the finished laundry tended to be not as soft as with just Tide powder alone.
It's up to you. If you have very hard water, then STPP may help considerably to prevent the redeposition of precipitated calcium and magnesium carbonates onto not only your laundry, but also on internal washer parts. Again, from the way it performs, I'm guessing the chemists at Tide have figured out how to minimize this without needing STPP. On the other hand, the municipal tap water here is moderately soft (2-5 grains) so this isn't as big a problem here as it might be at some place running on well water. |
Post# 943695 , Reply# 5   6/16/2017 at 04:03 (2,504 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 943771 , Reply# 6   6/16/2017 at 11:27 (2,504 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 943911 , Reply# 7   6/16/2017 at 23:30 (2,504 days old) by sudsmaster (SF Bay Area, California)   |   | |
I should hasten to add that STPP can function not only to prevent the deposition of hard water mineral precipitates on clothes and washer internals, but also to help break away and hold in suspension many of the same hard water minerals that are integral to soil on fabrics - you know, stuff like garden dirt. And perhaps also mineral based industrial or automotive grease. It does this better than any other single laundry additive.
However since the banning of phosphates in many products in many states and countries, the laundry detergent mfgs have devised various work arounds. IMHO, the early ones, which relied heavily on sodium carbonate, which can leave a mess when combined with hard water, didn't clean so good. It's my impression (not based on any insider knowledge) that mfgs like Persil and Tide have figured out how to get good results without phosphate. At least with their powders. I still don't think there's any liquids out there that can handle really filthy laundry as well as the top powders. The replacments for phosphates include such oddities as zeolites (basically, aluminum silicates that capture some but not all hard water minerals in their nooks and crannies, or odd sounding organic chemicals like TAENF whatever that is. Zeolites do a good job with calcium ions but not so good with magnesium and other hard water minerals. And so on ad nauseum. A while back I devised a home test for demonstrating part of the hard water mineral problem. In one jar I'd put some well water (we have soft muni tap water, but the well is for irrigation) and some standard laundry detergent. In another, some STPP. Shake them up, when the suds subside, you can actually see the flakes of precipitated out calcium and magnesium carbonate in the standard detergent jar, but the jar with STPP would remain crystal clear. And yes, the ppt looks like lint, but it's not so nice to have on finished laundry and it can put a layer of something akin to concrete inside the washer. |
Post# 944041 , Reply# 8   6/17/2017 at 21:10 (2,503 days old) by JesseD (Saint Marys, Pennsylvania)   |   | |
Since I am trying to clean dirt from a farm so I think it will defiantly help. |
Post# 944049 , Reply# 9   6/17/2017 at 23:15 (2,503 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 944157 , Reply# 10   6/18/2017 at 20:57 (2,502 days old) by panthera (Rocky Mountains)   |   | |
Post# 944184 , Reply# 11   6/19/2017 at 01:27 (2,502 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 944208 , Reply# 12   6/19/2017 at 08:23 (2,501 days old) by panthera (Rocky Mountains)   |   | |
Post# 944283 , Reply# 13   6/19/2017 at 18:34 (2,501 days old) by mamapinky (blairsville pa)   |   | |
I thought it was unsafe for washers and textiles to use tsp? |
Post# 944294 , Reply# 14   6/19/2017 at 20:02 (2,501 days old) by sudsmaster (SF Bay Area, California)   |   | |
Not really. It has to be damp and subjected to elevated temps.
However it's a good point to remember. Part of the power of STPP is that it carries a fair amount of chemical energy. It's this energy that enabled it to latch onto hard water minerals and hold them in suspension. As with most things, entropy is always increasing, which means systems tend to migrate from higher energy states to lower energy states. With STPP that means some of the polyphosphate structure can degrade to bi- and mono- phosphate. TSP is the mono-phosphate version. I have some STPP I've stored in the original sacks, kept in water resistant plastic tubs for over 10 years. Might be time to do another shaken pickle jar with well water test :-) |
Post# 944295 , Reply# 15   6/19/2017 at 20:05 (2,501 days old) by sudsmaster (SF Bay Area, California)   |   | |
I don't see why it would be, other than dumping phosphate into the waste stream with decreased benefit.
TSP is a milder alkali than the main ingredient in most laundry and dishwasher powders, sodium carbonate. So on that score it's more gentle than the main alkali in store bought. However, because it's a mono-phosphate, it won't keep hard water and soil minerals from precipitating out on fabrics and washer parts, same as sodium carbonate. In other words, it's no worse than unboosted store bought detergent, but not much better. |
Post# 944309 , Reply# 16   6/19/2017 at 23:13 (2,501 days old) by panthera (Rocky Mountains)   |   | |
Definitely does not harm to either clothes or water. I've never had the precipitate problem with it, and when a glass of our water falls it's an open question what breaks first, the glass or the water. That said, there's different mineral situations in each location so I don't exclude the possibility. As to cleaning, I must disagree - it does an outstandingly better job of grease and dirt removal and enzymatic detergents clean far, far better with it than without. As to STPP, I doubt most people who use it realize how quickly it degrades, so, yeah - most folks using "STPP" unless its fresh aren't. I still say - try the TSP. If it makes a big difference, invest in STPP. If it doesn't, STPP won't, either. |
Post# 944314 , Reply# 17   6/20/2017 at 00:01 (2,501 days old) by sudsmaster (SF Bay Area, California)   |   | |
I doubt that TSP would be a good indicator of how well STPP would boost laundry detergent, because it lacks the chelating ability of STPP that makes STPP so useful. Without that chelating ability one might just as well dump in more sodium carbonate (washing soda) instead.
As for STPP losing its special ability over time... I wonder if anyone has actual test data, or a literature reference, to back up the claim that it degrades rapidly even when kept dry and cool. Data should include storage conditions, including temperature and humidity, length of storage, and any quantified loss of chelating ability over time. Otherwise one might be tempted to dismiss such claims as unsubstantiated rumor. |
Post# 944331 , Reply# 18   6/20/2017 at 03:16 (2,500 days old) by Stan (Napa CA)   |   | |
There must have been a reason for the use of STPP by detergent manufactures vs using TSP. I know that TSP is more alkaline than STPP . Maybe TSP cleans better for wall washing...paint prep. TSP will cut through grease and etch into old paint making new paint adhere. (Needs to be rinsed, and ware gloves, made that mistake once)
But wait..why would that be good for laundry or fabric. If TSP does not suspend hard water, or form a complex with hard water ions...Then why use it in laundry? |
Post# 944347 , Reply# 19   6/20/2017 at 07:44 (2,500 days old) by panthera (Rocky Mountains)   |   | |
1) STPP is a much better laundry cleaner than TSP in hard water - it chelates the minerals which interfere with cleaning. No question. That's why I use it. 2) STPP deteriorates quickly if not properly stored - it's on every data sheet, we don't need to pretend it doesn't. 3) If we're now going to pretend TSP doesn't clean and that alkaline conditions are bad for laundry then we might as well just give up.
Nobody is saying STPP isn't wonderful - it is. I use it. BUT - TSP together with a good enzymatic laundry detergent and hot water cleans really well, especially greasy/oily stains.
Come on folks, are we really going to pretend it doesn't? Are we really going to pretend that one should spend the money on STPP without trying TSP first? That TSP doesn't clean?
Seriously?
Post# 944359 , Reply# 20   6/20/2017 at 09:51 (2,500 days old) by Stan (Napa CA)   |   | |
Post# 944377 , Reply# 21   6/20/2017 at 13:25 (2,500 days old) by panthera (Rocky Mountains)   |   | |
Post# 944383 , Reply# 22   6/20/2017 at 14:12 (2,500 days old) by stan (Napa CA)   |   | |
Post# 944385 , Reply# 23   6/20/2017 at 14:30 (2,500 days old) by panthera (Rocky Mountains)   |   | |
Post# 944397 , Reply# 26   6/20/2017 at 17:13 (2,500 days old) by stan (Napa CA)   |   | |
Post# 944413 , Reply# 27   6/20/2017 at 19:54 (2,500 days old) by kb0nes (Burnsville, MN)   |   | |
Paulo,
That is odd, I bought the exact same container from Chemistry Store. When I dummped the shot of powder into standing water in my top loader it was dissolved before it hit the bottom if of the basket. I left mine in the pail and slowly used it over the course of about a year. Never experienced anything like you describe... The powder was always free flowing as you mention and there was never any caking or issues with it dissolving. Strange |
Post# 944950 , Reply# 28   6/24/2017 at 00:33 (2,497 days old) by sudsmaster (SF Bay Area, California)   |   | |
STPP degredation:
I guess you (Panth) need to define "proper storage", and "quickly". Like I said before, if the STPP is kept dry and out of the heat, it will last in powder form for years. I know this from personal experience. Now, if you leave a cardboard box of it open under the kitchen sink next to damp garbage, yeah, it might degrade. Just like powder DW detergents will as well. But keep it dry and room temp or lower, it doesn't "degrade quickly". At least not in my book. |
Post# 944952 , Reply# 29   6/24/2017 at 00:38 (2,497 days old) by sudsmaster (SF Bay Area, California)   |   | |
STPP that is lumpy and won't dissolve?
Most likely old stock that was not properly stored. It's absorbed moisture. It might still work well enough. One could test its effectiveness by mixing it with warm or hot hard water in a glass jar, and noting if there's any visible precipitate. If none, then it's good to go. As a control, do the same with a precipitating water softener like washing soda or TSP. If you see a precipitate with those ( and you should with hard water ), then you know your test regimen is good. Don't have hard water? I suppose one could approximate it by mixing tap water with calcium cloride and magnesium sulfate. Next question. |
Post# 944997 , Reply# 30   6/24/2017 at 08:53 (2,496 days old) by panthera (Rocky Mountains)   |   | |
And they come to these conclusions: 1) At 0°C you can store STPP in water and it remains STPP. 2) At 20ºC the disappearance of STPP in water follows first order kinetics. I'm not posting all the conditions, methodologies, etc. so if you want them, do the research yourself - but: Worst case (that open cardboard box next to the disgusting garbage pail under the wet, dripping sink) it will have, thanks to the exponential increase in degradation, all turned into something else as fast as I keep saying it will. A few weeks and it's basically TSP. I stopped posting links when I realized people don't believe two plus two is four when they don't want to, but here's one site where a study may be bought - first page is free. It's enough for those who do actually believe 2 + 2 = 4. All the other studies I have found come to the same conclusion.
So, yes, if your STPP was always properly stored and you were really cautious with it then you can keep it for quite a while. Just, from everything I've read around here and elsewhere, if you've kept that 5 Kilo bag around for a few years anywhere but in the Arizona dessert - congratulations, you've been using TSP. Not to worry, though - it's a very good cleaner. So good, in fact, until a few decades ago it was the reason we had such clean clothes despite US washers having had such short cycles.
And, yes, since this seems to be vraiment important, TSP doesn't chelate hard water minerals out like STPP does. I love STPP, use it all the time - but dislike people pretending 2+2 doesn't = 4 just 'cause they don't like me.
Sheesh. I'd put any current detergent with the addition of TSP up against one without and guarantee the addition would improve the removal of body oils and cooking/automotive oils noticeably. CLICK HERE TO GO TO panthera's LINK |
Post# 945102 , Reply# 31   6/24/2017 at 20:35 (2,496 days old) by mamapinky (blairsville pa)   |   | |
Panthera, I have used better part of a 20 pound bag of STPP that took some work to disolve...so this could have decomposed into TSP if I'm reading you correctly...well I gotta say my clothes were wonderfully clean, fresh, and soft...LOL.....Cheryl |
Post# 945803 , Reply# 32   6/29/2017 at 00:44 (2,492 days old) by sudsmaster (SF Bay Area, California)   |   | |
Well, Panth, I still have a couple of 50 lb sacks of STPP I bought about 15 years ago - kept relatively cool and dry in plastic bins.
As I said earlier, I have a hard water well and I can easily test the ability of the STPP I have left to see if it still keeps hard water minerals suspended and not precipitated. It's a qualitative measurement, but I think a fairly good indication of STPP's chelating and complexing capability (forming chelated complexes with hard water minerals is what gives STPP its magic powers). I have no argument that storing STPP wet is a very bad idea. I just don't buy, without some solid evidence, that storing it dry is going to result in turning it to TSP. |
Post# 945846 , Reply# 34   6/29/2017 at 08:15 (2,491 days old) by panthera (Rocky Mountains)   |   | |
If anybody could store it properly, you are the type who could. The fact that nearly everyone else on the planet does not is the whole reason Automatic Detergent boxes containing the stuff warned not to keep it around too long, the whole reason commercial cleaners with it warn about proper storage. Come on, you're just being combative out of personal reasons. I've provide the scientific basis for my assertions, it's silly to mix personal feelings with fact.
STPP has wonderful cleaning abilities, I use it. But - this 'TSP' is of no value as a laundry/dish cleanser is just plain wrong. I've never had the problems with it which are theoretically possible. Water chemistry plays a role in that. So does accepting that STPP doesn't remain STPP for long unless stored with great care. |
