Thread Number: 73853
G.E. wwa8172hdmwh new washer |
Post# 975597 , Reply# 1   12/26/2017 at 14:42 (2,306 days old) by RP2813 (Sannazay)   |   | |
The wash and rinse temperature selections are self-explanatory. You would always want to select a cold rinse for the PERMA PRESS cycle.
The water level selections you will need to learn, as they generally are not the same among the various manufacturers. One way to do this would be to fill the tub while it is empty. Set to SMALL and let it fill. When it stops filling, turn the knob to RESET and then back to MEDIUM. Repeat this two more times for LARGE and EXTRA LARGE. It appears that your machine has infinite water level settings, which means you can set it somewhere in between for just the right amount of water, but again, you will need to learn how high these various settings fill the tub.
For speed selection, NORMAL will provide fast agitation/spin and DELICATE will provide slow agitation/spin. The PERMA PRESS setting probably provides fast agitation and slow spin.
The cycle selector dial is poorly marked. I've never heard of a soak at the end of a wash sequence, but that appears to be the case on your machine. It's likely just the deep rinse cycle that can be used as a manual soak sequence if desired. The main difference between the REGULAR cycle and PERMA PRESS cycle probably involves a partial first drain and refilling with cold water for the cool-down portion of the PERMA PRESS cycle. Other than that, it appears that the REGULAR cycle provides a longer wash period for heavily soiled items. I have rarely used the PERMA PRESS cycle on any washer I've owned. REGULAR uses less water.
The good thing about your washer is that it allows you to select the speeds rather than programming them in to the cycle. This gives you more flexibility in how you use the cycle options.
Post# 975601 , Reply# 2   12/26/2017 at 15:30 (2,306 days old) by appnut (TX)   |   | |
"Soak" on the regular cycle is simply the rinse portion of the cycle. Almost all GE washers had a "soak" marking at the beginning of the rinse portion of the regular cycle. The Permanent Press cycle likely has a longer spray rinse between wash and rinse to cool down the fabrics as it were. GE's largely did not do a partial drain and refill with cold water for cool down. My 1978 GE was a rarity in that regard. The on brands that did a partial drain and refill with cold water for the "cool down" was Whirlpool/Kenmore and also Maytag. |
Post# 975623 , Reply# 3   12/26/2017 at 18:37 (2,306 days old) by DADoES (TX, U.S. of A.)   |   | |
The "Soak" position operates as a sort-of manually controlled cycle. As Appnut says, it starts at the Final Rinse position of the Regular Cycle, but detergent or whatever you want to use for the soak treatment should be added. The machine fills with water (Cold or Warm per what is the RINSE on the temp knob setting), agitates for several minutes, then drain/spins and stops. The way to get an actual soak is by temporarily stopping the machine (press the timer knob IN without turning it) after it has agitated a couple minutes and let it sit for however long you want the soak. Then restart it (PULL the timer knob) to finish the remainder of the agitation and drain/spin. The load will not be rinsed. When it stops, restart it (add more detergent) to run whichever full wash-rinse-spin cycle is desired for the load. |
Post# 975625 , Reply# 4   12/26/2017 at 19:06 (2,306 days old) by rapunzel (Sydney)   |   | |
Hey Felipe, Congrats on your purchase. Why don't you use Google translate for the words on the washer controls. Easy peasy. Once you know what they are in Portugese the rest becomes self explanatory. |
Post# 975651 , Reply# 5   12/26/2017 at 23:45 (2,305 days old) by leefree (Los Angeles)   |   | |
Post# 975756 , Reply# 7   12/27/2017 at 14:06 (2,305 days old) by gewwa8172 (portugal)   |   | |
Thanks a lots people,i will test it with hot water and various cycles to undestand more of the functions. |
Post# 975811 , Reply# 8   12/27/2017 at 20:52 (2,305 days old) by appnut (TX)   |   | |
