Thread Number: 76596
/ Tag: Classified Ad Finds
Caloric Avocado Madness |
Post# 1004487   8/22/2018 at 14:30 (2,072 days old) by Stricklybojack (South Hams Devon UK)   |   | |
Post# 1004507 , Reply# 1   8/22/2018 at 17:10 (2,072 days old) by appnut (TX)   |   | |
Post# 1004509 , Reply# 2   8/22/2018 at 17:24 (2,072 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Does anyone looking at it need me to mention the seam between the cooktop and the side of the cabinet where grease accumulates? I found one and was going to use it outside, but that grease situation was just too gross. |
Post# 1004569 , Reply# 3   8/23/2018 at 07:55 (2,072 days old) by vacerator (Macomb, Michigan)   |   | |
Not many ranges back then were designed with easy cleaning in mind. Men didn't clean much, so why would they care? No sealed burners yet either. |
Post# 1004570 , Reply# 4   8/23/2018 at 07:57 (2,072 days old) by Jasonlittle (Southern iowa)   |   | |
Oh man! I love that! Wish it was closer and I had room. 😕 |
Post# 1004589 , Reply# 6   8/23/2018 at 12:30 (2,072 days old) by parunner58 (Davenport, FL)   |   | |
Here is the kitchen i grew up with, we had all avacado appliances. GE Potscrubber DW, Roper Double oven gas stove, Frigidaire Gemini 2000 S&S. This was taken about 1977.
Post# 1004622 , Reply# 7   8/23/2018 at 19:56 (2,071 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
A Transition between the Classic Calorics of old & the Whirlpool/Roper ownership creeping up...
Yes, CR downrates the cleanability of that cooktop enough that you wish for the grease-catcher design to be gone, then, again what excuse do I have? (Look here:) -- Dave
Post# 1004665 , Reply# 8   8/24/2018 at 07:29 (2,071 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
No GCT is truly easy to clean, and on this older non-sealed Caloric GCT you can easily lift the entire top up and off the range for cleaning [ you can clean it outside with Easy-Off ], then all the burners lift out, and you are left with an easy to clean porclean sub-top where nothing burns on.
The burner grates from the Caloric go in the Self-Cleaning, its a little bit of effort but as I said no gas range CT is as easy to clean as my Induction CT, LOL.
Post# 1004670 , Reply# 9   8/24/2018 at 08:52 (2,071 days old) by vacerator (Macomb, Michigan)   |   | |
Stains are difficult to get off the burners if they don't burn off. The grates are heavy, get greasy. A built in style collects grease and grime under the adjoining counter edge, and requires a toothpick to clean under. |
Post# 1004676 , Reply# 10   8/24/2018 at 10:09 (2,071 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Yes, that is what I was calling attention to—my counter edge, that I’ll go as far as to retrieve whatever food particles fall there that I don’t want to waste or don’t fall into any unusability...
Thankfully you can give credit to the modern designs for making cleanup easier than on the range tops of old...! — Dave |
