Thread Number: 76663
Sympathetic Spin Solved! |
Post# 1005164   8/28/2018 at 07:50 (2,065 days old) by turquoisedude (.)   |   | |
This is a record of some kind for me. I managed to get the inevitable "do-over" of one of my restorations over and done with within just one month of the initial restore, but I also managed to repair a GE washer transmission! I admit it, I was scared like hell however, thanks to the information found on this site and a copy of the original GE manual for my 1957 GE Filter Flo washer I did it! Recall that the GE WA857 (Canadian version of the WA855) was finally restored, but on the 2nd and 3rd loads of laundry done with it I noted the dreaded 'sympathetic spin'. I'd been dithering over working on this machine for years, so I wasn't ready to give up just yet. The machine was pulled out of service and I dismantled it in the laundry room (the 55 Norge got to be the 'place filler'). This was the easy part... |
Post# 1005165 , Reply# 1   8/28/2018 at 07:53 (2,065 days old) by turquoisedude (.)   |   | |
Here's what scared me.... I guess it wasn't such a bad thing that I messed around with that poor 1960 GE washer transmission, even though it was beyond hope. I managed to crack the 57 transmission open fairly quickly. Look! This one still has oil in it!! |
Post# 1005167 , Reply# 2   8/28/2018 at 07:59 (2,065 days old) by turquoisedude (.)   |   | |
Again, as documented in a thread by jetcone (Jon), the snubber brake assembly is on the transmission cover plate. When the machine is running and the transmission is in an upright position, that nylon part, the snubber, shown in the last picture would be pointed down. As the transmission shaft rotated, it would contact the brake band tang; this would prevent the washer tub from turning in a clockwise rotation while the washer is agitating. The brake bands wear out (even after only nearly 61 years... LOL) and slip. This is what causes the 'spin in activation' condition described in the GE service manual. Sonny Service sure got that description right.
Post# 1005168 , Reply# 3   8/28/2018 at 08:01 (2,065 days old) by turquoisedude (.)   |   | |
It took some doing to snap that subber brake band off and as I did so, it refused to stay still. No wonder - that old brake band is worn out but good...
Post# 1005169 , Reply# 4   8/28/2018 at 08:05 (2,065 days old) by turquoisedude (.)   |   | |
I owe Jon big time - not only did he find someone who was willing to make a brake band like this, the person who did this still had Jon's specs and sample from his 1956 Filter Flo. This was a huge bonus for me - the lining for the 1956 and 1957 models are identical, so I got a new brake in about a week. It was not too bad to install and it sure didn't slip any more! |
Post# 1005171 , Reply# 5   8/28/2018 at 08:10 (2,065 days old) by turquoisedude (.)   |   | |
I posted a couple of question regarding the transmission seals, since I did have a set for this model GE. As it turned out, I chose not replace the lower seal because of the condition of the basket drive hub. However, the upper (activator) seal leaked fairly badly. It looked like the Santa Barbara oil spill on the garage floor while I had the transmission upside down to remove the drive plate.... OOPS. I almost had a panic attack when I replaced the top seal and I noticed that I didn't have the cap that is installed above the seal. Amazingly, in the box of parts I got years from Larry at Modern Parts there was a note he wrote me to explain how to re-use the original cap with a newer-style top seal. Even from the Great Beyond, Mr. Olmo was still able to help me out. Scary stuff!!! |
Post# 1005172 , Reply# 6   8/28/2018 at 08:14 (2,065 days old) by turquoisedude (.)   |   | |
I didn't take more photos of the top seal... sorry 'bout that... I had a wee potential problem with a seal for the drive pulley bolt, but as previously posted, Robert's suggestion of cutting a new seal and reinforcing with silicone worked wonderfully. The transmission held it's oil during overnight testing - phew! I put in new oil, of course. I used the recommended 54 ounces of 40-weight non-detergent engine oil.
Post# 1005173 , Reply# 7   8/28/2018 at 08:21 (2,065 days old) by turquoisedude (.)   |   | |
This is always the 'fun' part of a major repair like this. Even I have learned that it's best not to rush things and make sure things like seals and gaskets go back together the way they should... I did a water test following the reinstallation of the transmission boot - no leaks! I also saw a potential boo-boo from round 1 of this restoration - I had neglected to put in a drain baffle on the tub drain. Oddly enough, when I dismantled the machine the first time around, there was no baffle. Perhaps the previous owner had some serious work on this machine done... What I did manage to do was tear the suds-return nozzle... GGGRRR.... I beefed it up with some auto weatherstripping adhesive and it seemed to hold. While I didn't manage to bust the fill flume (you'd have heard the swearing in both official languages if I had...) I did notice some splash-back while the washer was filling, causing a dribble down the back of the tub. Funny, but I didn't see this last time around. Anyway, I improvised a splash guard of sorts... Not pretty, but it works! |
Post# 1005174 , Reply# 8   8/28/2018 at 08:23 (2,065 days old) by turquoisedude (.)   |   | |
Post# 1005175 , Reply# 9   8/28/2018 at 08:24 (2,065 days old) by turquoisedude (.)   |   | |
Post# 1005176 , Reply# 10   8/28/2018 at 08:26 (2,065 days old) by turquoisedude (.)   |   | |
I was a little concerned about how much the tub was still indexing... But that was a darned big load of laundry! There were no oil spots on the robes and towels - so that top seal held! And of course, this load of washing had to be dried, automatically of course, in the matching 57 GE Clothes Conditioner. Do I get my 'GE Badge' now?? |
Post# 1005203 , Reply# 11   8/28/2018 at 13:19 (2,065 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Excellent work, Paul! That is really a very pretty set, GE solid tub washing is one of my favorites - that tub holds more than you'd imagine just peering in the top.
I should get the name and info for the guy who did the brake band, mine will likely need it one day. Congrats on your hard work paying off, it looks and sounds great! |
Post# 1005206 , Reply# 12   8/28/2018 at 13:40 (2,065 days old) by turquoisedude (.)   |   | |
Thanks, Greg! Chris is still dumbstruck that I pulled this off... LOL Here's the information about the place where the brake bands were made (information previously posted by Jon about his '56 Filter Flo): Timothy J. Doran AllFrictions LLC 131 Freestone Avenue, Portland, CT 06480-1819 Tel: 860-342-2001 Fax: 860-342-2084 info@allfrictions.com website: www.allfrictions.com ... The owner, Timothy Doran, is geniunely interested in the need for parts like these and is happy to help out. If my nerve holds, I'm thinking of dismantling that 57 Hotpoint clutch of mine and seeing if they can re-line the shoes... |
Post# 1005209 , Reply# 13   8/28/2018 at 13:55 (2,065 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 1005210 , Reply# 14   8/28/2018 at 13:56 (2,065 days old) by sfh074 ( )   |   | |
That is one beautiful set! Awesome job Paul. Love how you document the progress here on AW. Keep it coming! Bud - Atlanta |
Post# 1005216 , Reply# 15   8/28/2018 at 14:15 (2,065 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 1005227 , Reply# 16   8/28/2018 at 15:03 (2,064 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 1005232 , Reply# 17   8/28/2018 at 15:28 (2,064 days old) by Unimatic1140 (Minneapolis)   |   | |
That's a good question Ben. My guess would be yes only because so much of GE's washer transmission parts were standardized and fit from the early direct-drive AW6 through the end of the Filter-Flo's in the mid 90's. However I'm not sure, but if the lining is too large length wise it can always be trimmed down. The only issue I can see would be if the replacement lining is too small. |
Post# 1005233 , Reply# 18   8/28/2018 at 15:37 (2,064 days old) by pulltostart (Mobile, AL)   |   | |
Post# 1005235 , Reply# 19   8/28/2018 at 15:37 (2,064 days old) by Stricklybojack (South Hams Devon UK)   |   | |
