Thread Number: 76810
Refilling a transmission |
Post# 1006693   9/10/2018 at 19:47 (2,052 days old) by Softheatwash (Arizona)   |   | |
Post# 1006703 , Reply# 2   9/10/2018 at 20:38 (2,052 days old) by Softheatwash (Arizona)   |   | |
Post# 1006720 , Reply# 3   9/10/2018 at 22:44 (2,052 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Is easy, you take an approximately 5" section of coat hanger wire, bend a little loop handle on one end so you still have 4" of the wire straight to use as a dipstick.
From the back of the washer with the service panel removed drop the straight end of the wire into the vent hole in the center of the transmission it will probably go in about an inch and a half, but it needs to go to the bottom which is about 2& 1/2". If it only goes in 1&1/2"leave the DS in place and turn the drive belt by hand from right to left till the DS drops in 2&1/2". When you pull it out you can now see the oil depth, it should be from 3/8" to just over 1/2" deep, the best thing about this test is you can see if the oil is milky colored [ water is in it ] or is brown and rusty [ water has been it for a long time ]
We always did this oil test on any BD washer we were refurbishing to check the condition of the oil, unfortunately if the level is way too low or the oil is contaminated you have to pull the transmission to correct the problem.
