Thread Number: 76844
Is this a bad bearing? |
Post# 1007106 , Reply# 1   9/13/2018 at 19:54 (2,050 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 1007119 , Reply# 2   9/13/2018 at 21:17 (2,050 days old) by Dlew56 (Pa)   |   | |
It’s a wjsr2070b2ww GE washer and the transmission is WH38X10002 It’s taken apart right now |
Post# 1007123 , Reply# 3   9/13/2018 at 22:27 (2,050 days old) by deltablu (Eastern South Dakota)   |   | |
Likely a bad trans. When these spin they make a loud hollow noise that is a dead giveaway for bearing failure. It'd be easier to know if that's all you have bad if there was vid of it in the machine while spinning. |
Post# 1007174 , Reply# 4   9/14/2018 at 10:45 (2,050 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The disk you are spinning has a good bearing and is not the cause of your noise problem, it sounds like that the basket may be broken loose, normally a bad bearing will make a ton of noise but the tub assembly will not thrash about, but again a video of the machine operating would help a lot.
