Thread Number: 76872
G E WASHER |
Post# 1007296   9/15/2018 at 10:13 (2,021 days old) by frigidaireguy (Wiston-Salem, NC)   |   | |
I have a GE washer Model #WWA2250GALWH - Serial # VS1 09729G - It is leaking water and we have determined the water pump has a hole in it. Trying to find a water pump. Any suggestions ???? Pic Enclosed Bob
Post# 1007325 , Reply# 3   9/15/2018 at 17:21 (2,021 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 1007329 , Reply# 4   9/15/2018 at 17:44 (2,021 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The hole in the pump is not the cause of the leak but rather the water seal has failed, the hole is there as a weep hole to allow tiny amounts of moisture to escape so it does not damage the bearings.
Luckily these pumps are still readily available, A new one will be heat sealed together so it will look a little different than your old one. John L. |
