Thread Number: 77078
Maytag swap A806 innards with an orbital |
Post# 1010105   10/8/2018 at 12:20 (2,020 days old) by PeterH770 (Marietta, GA)   |   | |
Hi Guys,
I'm looking for videos and cannot seem to find anything... I have an A806 that is leaking oil into the tub (ruined 2 loads before I caught it). I have an extra orbital Maytag, and want to swap its innards with the A806. It appears that the clutch under the cabin base needs to be removed, and the entire interior can be lifted out. Do I understand this correctly? Am I risking an oil spill in my carport? |
Post# 1010106 , Reply# 1   10/8/2018 at 12:37 (2,020 days old) by good-shepherd (New Jersey)   |   | |
Maytag A806 doesn't have a clutch. To swap in an orbital trans the tub must be removed and you'll also need to use the orbital style agitator which it sounds like you have. Good time to replace the tub bearing and mounting stem as well. |
Post# 1010123 , Reply# 2   10/8/2018 at 14:57 (2,020 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 1010124 , Reply# 3   10/8/2018 at 15:05 (2,020 days old) by good-shepherd (New Jersey)   |   | |
Okay, then the brake assembly needs to come off. |
Post# 1010128 , Reply# 4   10/8/2018 at 16:02 (2,020 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 1010132 , Reply# 5   10/8/2018 at 16:07 (2,020 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
