Thread Number: 77170  /  Tag: Modern Automatic Washers
2.6 Capacity Front Load Washer
Post# 1011143   10/17/2018 at 07:49 (2,008 days old) by roscoe62 (Canada)
Can a 2.6 capacity front load washer hold / clean a double / full size comforter? I haven't seen one on display to compare, if anyone can help.
Tks
Post# 1011152 , Reply# 1   10/17/2018 at 10:02 (2,008 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
combo52's profile picture
Yes easily unless it is VERY thick or over 18 pounds in weight.
John L.
Post# 1011153 , Reply# 2   10/17/2018 at 10:33 (2,008 days old) by roscoe62 (Canada)
Interesting
since the sales staff I spoke with on the phone in two separate stores had conflicting replies.
I'm considering down sizing my machines because I have limited space in the laundry area with no room left for you to deal with a hose or venting problem.
Thank you Combo52
Post# 1011154 , Reply# 3   10/17/2018 at 10:52 (2,008 days old) by henene4 (Heidenheim a.d. Brenz (Germany))
A washer with recirculation pump would handle it better, but any should be capable.
Post# 1011156 , Reply# 4   10/17/2018 at 11:17 (2,008 days old) by volsboy1 (East Tenn Smoky mountains )
volsboy1's profile picture
I never had a problem washing them in the 2.2 cf front loaders I had ..No problems at all. I would jam pack those washers .. They wash very well.
Post# 1011157 , Reply# 5   10/17/2018 at 11:47 (2,008 days old) by Yogitunes (New Jersey)
yogitunes's profile picture
the sales staff is the LAST person you should ask, and expect an honest answer....
always ask a mechanic, or someone who actually owns and uses one....now or in the past.....
I have a washer like this, which is not much bigger than what your considering, and handles a king size quilt with no issues....
Post# 1011164 , Reply# 6   10/17/2018 at 15:16 (2,007 days old) by Launderess (Quiet Please, There´s a Lady on Stage)
launderess's profile picture
Much will depend upon what sort of filling inside comforter or quilt.
Down and feathers will compact quite a lot once wet and or air expelled. Polyester and other man made fibers will not.
You'd be surprised at how even a large king sized down duvet looks like nothing by end of washing after final spin has removed air/water. In fact many front loaders with a dedicated "duvet" cycle begin with spinning item first to remove air/flatten.
Post# 1011171 , Reply# 7   10/17/2018 at 15:52 (2,007 days old) by Taurn67 ()
should be fine
I have a Maytag 2.4 cu/ft machine and it does a full size poly flll comforter with no issue, no issue with doing down filled duvet in it either.
Post# 1011256 , Reply# 8   10/18/2018 at 09:03 (2,007 days old) by roscoe62 (Canada)
Downsizing
won't be so difficult after reading this, just making a decision on which set to buy, as there are not many choices out there after some of the reviews I've read on what is available to buy.
Tks
Post# 1011268 , Reply# 9   10/18/2018 at 09:30 (2,007 days old) by henene4 (Heidenheim a.d. Brenz (Germany))
Depending on investment scale, Miele offers awesome machines (and heatpump dryers) while Electrolux has the better value.
