Thread Number: 77207
/ Tag: Vintage Dishwashers
KDI-16 in new house doesn't run |
Post# 1011888 , Reply# 1   10/23/2018 at 07:32 (2,006 days old) by dermacie (my forever home (Glenshaw, PA))   |   | |
Post# 1012293 , Reply# 4   10/27/2018 at 19:05 (2,001 days old) by barcoboy (Canada)   |   | |
In your third photo, the inlet valve is the white plastic assembly which is attached with a metal bracket and two screws to the cross member running along the front of the machine. It is immediately to the right of the "NOTE" decal. It also has the copper pipe attached to it, which is your hot water source.
Post# 1012428 , Reply# 7   10/29/2018 at 04:30 (2,000 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 1012446 , Reply# 8   10/29/2018 at 10:42 (1,999 days old) by eronie (Flushing Michigan)   |   | |
Don't loose the washer that's underneath if it's still there. |
Post# 1012548 , Reply# 9   10/29/2018 at 23:32 (1,999 days old) by Brandt (Portland)   |   | |
It took some hard pulling, but it came up. No washer was present. I found some broken glass in there, but nothing that seemed to have been burning.
Post# 1012601 , Reply# 10   10/30/2018 at 02:24 (1,999 days old) by RP2813 (Sannazay)   |   | |
There's the heating element Steve was wondering about.
Since a single valve supplies both the machine and your sink faucet, if you have hot water at the sink, then you should also have hot water at the inlet valve. It's only a temporary inconvenience if there's no hot water at the sink while you have the inlet valve pulled for inspection and testing.
I would check the inlet screen first. Crud can build up there and reduce the flow of water to almost nothing. Otherwise it might be a solenoid issue. |
Post# 1012879 , Reply# 13   11/1/2018 at 07:36 (1,997 days old) by bigalsf (Salt Lake City)   |   | |
You’re welcome. Glad it worked. This is a great dishwasher, built like a tank! With proper use (& care) it will last you many years. Enjoy! |
Post# 1012881 , Reply# 14   11/1/2018 at 08:05 (1,997 days old) by dermacie (my forever home (Glenshaw, PA))   |   | |
