Thread Number: 77334
Maytag A407 Brake Problem |
Post# 1012944   11/1/2018 at 22:22 (1,973 days old) by eurekastar (Amarillo, Texas)   |   | |
Tonight, I was making a video (which is attached) and I noticed the tub brake is not stopping the tub after it spins. The tub is also freely moved by hand when the washer is off. Not sure what's wrong. It is a brand new brake assembly, so I'm sure there's a problem with how I installed it. Any thoughts would be appreciated! CLICK HERE TO GO TO eurekastar's LINK |
Post# 1012955 , Reply# 1   11/2/2018 at 00:21 (1,973 days old) by eurekastar (Amarillo, Texas)   |   | |
Well, after looking at the service manual, I think I had the drive lug key adjusted incorrectly. So I tipped it over and followed the procedure in the manual and it works fine. I also discovered that I had the tension on the pump belt too loose. So I tightened it, and that fixed the slow pump out rate.
Post# 1012966 , Reply# 2   11/2/2018 at 03:10 (1,973 days old) by DADoES (TX, U.S. of A.)   |   | |
