Thread Number: 77544
/ Tag: Classified Ad Finds
KDS-19 $65 (Asheville, OH) |
Post# 1015339   11/21/2018 at 19:00 (1,954 days old) by spacepig (Floridas Emerald Coast)   |   | |
Per the ad: "I bought this a year ago still in the shipping container. It is old but was brand new and never used. I have used it for a year or less. It works great. Because of my well water there is a stain on right side on the inside. The pump is what Hobart uses in the industrial dishwashers it makes today. This is an amazing well built dish washer. The pump costs more than I am listing it for."
CLICK HERE TO GO TO spacepig's LINK |
Post# 1015361 , Reply# 1   11/21/2018 at 22:46 (1,954 days old) by Streakers (Columbus Ohio)   |   | |
This is literally 15 minutes from me! Pity I have no need for it... 🤷🏼♂️ |
Post# 1015385 , Reply# 2   11/22/2018 at 04:30 (1,954 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I bought that machine Brand New in 1981. That was my first KitchenAid.
The No Heat Dry worked OK on the Soak and Scrub Cycle. But all and all.. a fantastic cleaner. If I had the technological wisdom, hooking up a heated blow dryer from a 17 series, You'd basically have a KDS-20. The cycles were different on the 20 as far as sequence goes. |
Post# 1015490 , Reply# 3   11/23/2018 at 08:40 (1,952 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These were very good machines, they actually dry better than the KDS-17A and the KDS-18 do when you use those on the Energy-Saver no heat drying setting.
This machine heats the final rinse to 150F and then uses a much more powerful blower than the other aforementioned models so it actually does a better job on air dry. [ yes if you want to squander 1/2 KW of power using heated dry on the other models with heated dry the dishes will be dryer when you open the door after a run ] But I am perfectly willing to let the dishes finish air-drying to save the power and extra damage to the machine that heat drying causes.
If you want even better automatic drying from a KDS-19 use the sani-rinse option that raises the final rinse to 165F, using Soak&Scrub will not make any difference in the drying unless maybe you are operating the machine on cold water, LOL
Post# 1015491 , Reply# 4   11/23/2018 at 08:45 (1,952 days old) by peteski50 (New York)   |   | |
Post# 1015551 , Reply# 5   11/23/2018 at 18:49 (1,952 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
