Thread Number: 77587
HELP! Does ANYBODY have a * MAYTAG - LA710 * Washing Machine??? |
Post# 1015907 , Reply# 1   11/26/2018 at 20:54 (1,976 days old) by Yogitunes (New Jersey)   |   | |
Post# 1015908 , Reply# 2   11/26/2018 at 20:56 (1,976 days old) by Yogitunes (New Jersey)   |   | |
Post# 1015909 , Reply# 3   11/26/2018 at 20:57 (1,976 days old) by Yogitunes (New Jersey)   |   | |
Post# 1015910 , Reply# 4   11/26/2018 at 21:18 (1,976 days old) by RP2813 (Sannazay)   |   | |
Shout out to Tinley Park! My mom was born and raised there when it was still all farmland.
Keep an eye on craigslist for used machine like those Martin has posted above. You will need to look for one that has the same number of slots down the side of the agitator as your OOS 710 or the tub won't interchange.
Milwaukee isn't out of the question, but if you can tolerate your substitute machine for a while longer, something is bound to turn up closer to home. I suggest buying a working Maytag equivalent of similar or older vintage and keeping your 710 for parts. |
Post# 1015985 , Reply# 5   11/27/2018 at 17:03 (1,975 days old) by goatfarmer (South Bend, home of Champions)   |   | |
I scrapped a LA 710 about a month ago. It worked OK, but leaked through the center, and the damper pads were worn out, and had been for a long time.
Washer in Palatine. CLICK HERE TO GO TO goatfarmer's LINK on Chicago Craigslist |
Post# 1015991 , Reply# 6   11/27/2018 at 17:17 (1,975 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1015999 , Reply# 7   11/27/2018 at 17:34 (1,975 days old) by bendixmark (Winchester Mass)   |   | |
Those tubs are plentiful.I will keep an eye out for one I work in the field.That tub was used on all the 10 and 12 series maytags and later.Have you tried patching the hole with clear silicone? |
