Thread Number: 77733
SQ parts |
Post# 1017602   12/10/2018 at 14:40 (1,962 days old) by backspace (Ct)   |   | |
Where is the best place to purchase genuine SQ parts? Directly from SQ? Thanks |
Post# 1017603 , Reply# 1   12/10/2018 at 14:46 (1,962 days old) by Yogitunes (New Jersey)   |   | |
Post# 1017666 , Reply# 3   12/11/2018 at 06:53 (1,962 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There is probably no reason to buy any parts now for these machines,
This W&D are so reliable that unless you are doing more than 10 loads a week it is very likley that they will require NO SERVICE for more than a decade.
And the parts you are eventually going to need will be readily available for more than 20 years.
If you were willing to stash parts so you could repair the machines instantly and did not care that you would be spending several hundred on parts that 70% of would never be used I would get the following parts for the washer.
A belt, an inlet valve, a timer, a water pump and maybe a spare motor.
For the dryer, A belt ,a set of rear rollers and a timer, and again maybe a motor.
Post# 1017738 , Reply# 6   12/12/2018 at 04:46 (1,961 days old) by Lorainfurniture (Cleveland )   |   | |
Lmk it should work now. |
