Thread Number: 77748
Kenmore washer won't drain, spin, or agitate |
Post# 1017887 , Reply# 1   12/13/2018 at 16:04 (1,957 days old) by Yogitunes (New Jersey)   |   | |
Post# 1017928 , Reply# 2   12/13/2018 at 21:10 (1,957 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
Post# 1017969 , Reply# 3   12/14/2018 at 09:16 (1,956 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1017992 , Reply# 4   12/14/2018 at 10:44 (1,956 days old) by radioboy75 (Rock Rapids, IA, USA)   |   | |
That's what I think too. Sounds like a belt. The motor does run. We'll take a look. Thanks guys. |
Post# 1018339 , Reply# 6   12/17/2018 at 19:21 (1,953 days old) by Yogitunes (New Jersey)   |   | |
Post# 1018340 , Reply# 7   12/17/2018 at 19:28 (1,953 days old) by DADoES (TX, U.S. of A.)   |   | |
The motor does not reverse. Runs one direction, mode shifting (agitate, spin, or neutral drain with neither solenoid energized) is done by the wigwag per the video Martin linked. Are you assuming the belt is not at fault because it sometimes does work? You should check the belt if you haven't already. Maybe the motor pulley is loose? |
Post# 1018361 , Reply# 8   12/17/2018 at 21:09 (1,953 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
Post# 1018424 , Reply# 9   12/18/2018 at 13:27 (1,952 days old) by radioboy75 (Rock Rapids, IA, USA)   |   | |
Thanks guys. We'll check it out. |
Post# 1018630 , Reply# 11   12/20/2018 at 16:40 (1,950 days old) by DADoES (TX, U.S. of A.)   |   | |
Could be a foreign object was jammed in it that broke loose with the forced turning of the pulley. You might consider removing the pump and looking into the ports to confirm no remnants of said object. Could also be the pump impeller was damaged or the object is still obstructing the flapper valve from fully seating one way or the other which could impact proper draining or cause draining during agitation. |
Post# 1018636 , Reply# 12   12/20/2018 at 17:49 (1,950 days old) by Yogitunes (New Jersey)   |   | |
yeah, its great it broke free....
my concern would be, what was it that clogged/jammed it?....and then, where did it go? straight out the drain hose, that would be a good thing.....or pumped back into the machine or the self clean filter.... either way, you will find out in time.....good luck with it.... |
