Thread Number: 77852
/ Tag: Modern Dryers
Whirlpool gas dryer snafu... |
Post# 1018871   12/22/2018 at 18:56 (1,942 days old) by stricklybojack (South Hams Devon UK)   |   | |
The situation is it doesn’t run. No hum, no nuttin’. Previous owner trying to track down the problem replaced the timer and start switch then gave up. I was told it “is only a couple of years old”. I checked the door switch for “click” and continuity, and also the thermistor on the fan assembly. Both were fine. Drum turing well, belt fine, etc. What next, start button relay? If so, is that in the control panel? |
Post# 1018873 , Reply# 1   12/22/2018 at 19:34 (1,942 days old) by Lorainfurniture (Cleveland )   |   | |
If you could post a pic of the wiring diagram that would be helpful |
Post# 1018875 , Reply# 2   12/22/2018 at 19:44 (1,942 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 1018885 , Reply# 3   12/22/2018 at 22:07 (1,942 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The door switch could also be at fault. If you push it in and it does not click, it should be tested. |
Post# 1018889 , Reply# 4   12/23/2018 at 01:46 (1,942 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1018916 , Reply# 5   12/23/2018 at 13:45 (1,942 days old) by stricklybojack (South Hams Devon UK)   |   | |
Post# 1018918 , Reply# 6   12/23/2018 at 14:31 (1,942 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1018926 , Reply# 7   12/23/2018 at 15:57 (1,941 days old) by stricklybojack (South Hams Devon UK)   |   | |
Thx for help. I just sent it down the road for $30. I spent over an hour cleaning it up thoroughly, drum out etc. I hope they fix it. Probably was the motor. I saw signs of water or fluid having been present around the motor area. I have to clear lots of space, so a dozen major appliances and 100 vacuums need to find new homes ASAP. |
Post# 1019124 , Reply# 8   12/26/2018 at 11:17 (1,939 days old) by Searsbest (Attleboro, Ma)   |   | |
