Thread Number: 77881
/ Tag: Twin-Tub Washers
Easy spindrier |
Post# 1019188 , Reply# 1   12/27/2018 at 10:27 (1,945 days old) by abcomatic (Bradford, Illinois)   |   | |
HI, Good luck with your Easy. I would lubricate the controls under the machine first; make sure that all of that easy to move. Try that and see what happens. Gary |
Post# 1019208 , Reply# 3   12/27/2018 at 12:39 (1,945 days old) by rpms (ontario canada)   |   | |
Post# 1019218 , Reply# 4   12/27/2018 at 14:44 (1,944 days old) by electroluxxxx (Syracuse NY)   |   | |
I believe it is a drain lever. |
Post# 1019282 , Reply# 6   12/28/2018 at 09:47 (1,944 days old) by electroluxxxx (Syracuse NY)   |   | |
thanks Gary! I will give that a shot. There are quite a few videos of these in action on youtube and they seem to be pretty impressive in terms of rollover action. |
Post# 1019298 , Reply# 7   12/28/2018 at 14:06 (1,943 days old) by abcomatic (Bradford, Illinois)   |   | |
Mike, If you get this to all work, you will amazed at how they wash. The spiralator really turns the clothes over. |
Post# 1019346 , Reply# 9   12/28/2018 at 23:14 (1,943 days old) by abcomatic (Bradford, Illinois)   |   | |
Mike, If the seal under the washer tub is good, I wouldn't mess with it. The weakest part of this machine is the pump. Look to see where the water is leaking from to determine where the seals etc. may need to be replace. |
Post# 1019661 , Reply# 10   1/1/2019 at 02:06 (1,940 days old) by abcomatic (Bradford, Illinois)   |   | |
Mike, how are you coming along with the Easy? |
Post# 1019724 , Reply# 11   1/1/2019 at 14:59 (1,939 days old) by Electroluxxxx (Syracuse NY)   |   | |
With the holidays I have not been able to bite into it just yet. I might attempt to tackle part of it this weekend coming up. Thanks for asking 😊 |
Post# 1021910 , Reply# 16   1/21/2019 at 02:28 (1,920 days old) by abcomatic (Bradford, Illinois)   |   | |
HI Mike, Any update on the Easy? You are right, it is a pain to work on. On your back, lying on the floor and trying to get to things that need attention. Not of the faint hearted. Gary |
Post# 1021993 , Reply# 18   1/21/2019 at 23:43 (1,919 days old) by abcomatic (Bradford, Illinois)   |   | |
Good luck with all of this. Your machine looks older than mine does. I have one that has the controls all in the middle,; the cables that run all of the functions must be lubricated so that they work well. |
Post# 1022015 , Reply# 19   1/22/2019 at 09:18 (1,919 days old) by Electroluxxxx (Syracuse NY)   |   | |
I’d say you have the “automatic” version as to where mine is the “manual” or stick shift. Thanks for the wishes of good luck! I know I’m going to need it. |
Post# 1022061 , Reply# 20   1/22/2019 at 15:20 (1,918 days old) by abcomatic (Bradford, Illinois)   |   | |
I think mine was made are around 1960 or so. The levers have to be lubed up or they wont work.they are hooked up to cables and they must all move freely. I would sooner have your version. |
Post# 1022078 , Reply# 21   1/22/2019 at 17:02 (1,918 days old) by electroluxxxx (Syracuse NY)   |   | |
sent you an email Gary |
