Thread Number: 78183
/ Tag: Vintage Dryers
GE Dryer |
Post# 1022107   1/22/2019 at 22:06 (1,919 days old) by Stricklybojack (South Hams Devon UK)   |   | |
I am thinking of picking this up, anything special about these? What’s the 411, Yogitunes, are you out there? |
Post# 1022116 , Reply# 1   1/22/2019 at 22:54 (1,919 days old) by Yogitunes (New Jersey)   |   | |
What do you want to know?
I have that exact dryer....pretty much every feature you could get from GE at the time...this would date around 1985 this should also have a tub light..... even though this is a 27" cabinet, there is an extension on the rear that accommodates the deeper drum of a true ExLarge capacity....also a true match to the ExLge Washer I found this capacity model safer for fabrics, as the heat source is located in the bottom of the machine....as for the standard capacity model, especially for electric, had the element right at the back, causing the rear of the drum to get really hot for loads like blankets causing scorching.... most servicing can be done from the front, except for attaching the belt to the motor via a small panel on the rear... you will want to pull the drum to clean all lint from the rear intake, a lot gets trapped in that area...and grease the drum bearing...
Post# 1022244 , Reply# 2   1/23/2019 at 22:45 (1,918 days old) by Stricklybojack (South Hams Devon UK)   |   | |
Post# 1022249 , Reply# 3   1/24/2019 at 01:33 (1,918 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 1022300 , Reply# 4   1/24/2019 at 13:52 (1,917 days old) by good-shepherd (New Jersey)   |   | |
Nice.. Porcelain enamel top cover and drum on those machines. How much did you pay? |
Post# 1022429 , Reply# 5   1/25/2019 at 12:55 (1,916 days old) by stricklybojack (South Hams Devon UK)   |   | |
Is that bulb missing a lens? Orherwise thos machine looks more months old than years. |
Post# 1022442 , Reply# 6   1/25/2019 at 15:19 (1,916 days old) by pulltostart (Mobile, AL)   |   | |
