Thread Number: 78554
Maytag A606S Problems |
Post# 1025637 , Reply# 1   2/25/2019 at 20:35 (1,884 days old) by swestoyz (Cedar Falls, IA)   |   | |
Is your Maytag in a cold basement or room that is typically cold in the winter? Often times the cooler temps can cause the now 40-50 year old gear case grease to take several minutes to reach an operating temp where agitation is normal. This isn’t going to really hurt anything now - long term fix would be a full trans clean and rebuild.
Ben |
Post# 1025650 , Reply# 2   2/25/2019 at 22:20 (1,884 days old) by RP2813 (Sannazay)   |   | |
Post# 1025679 , Reply# 3   2/26/2019 at 05:28 (1,884 days old) by JesseD (Saint Marys, Pennsylvania)   |   | |
I wouldn’t say the basement is cold as the wood burner is in that room also but it is against a stone wall where a draft comes through the door. The room is usually between 60 and 80 degrees F. |
Post# 1025712 , Reply# 4   2/26/2019 at 11:55 (1,884 days old) by RP2813 (Sannazay)   |   | |
60 is cold enough to slow it down. My experience has been that it usually only takes about a minute of operation for it to get up to speed. You also need to take into account what is being washed. If it's a full load of towels, sometimes even on a warm day agitation speed can vary somewhat until the entire load has turned over. |
