Thread Number: 79067  /  Tag: Vintage Automatic Washers
Westinghouse Slant Front D8 Belts...
Post# 1030130   4/17/2019 at 14:40 (1,826 days old) by bellalaundry (St. Catharines, Ontario, Canada)
bellalaundry's profile picture
I'm wondering if anyone has replaced theirs, or if there is a resource for actual belt numbers or dimensions?
I removed them and brought them to a large auto parts place. The belts I got were "slightly" wider. I couldn't get them to work. Thank goodness I can return them.
I'm always hesitant to go to an appliance parts store because they are usually so anal about part numbers.
Any ideas or suggestions?
Thanks!
Guy
Post# 1030131 , Reply# 1   4/17/2019 at 14:58 (1,826 days old) by Unimatic1140 (Minneapolis)
For exact original size Westinghouse Laundromat washer replacement drive belts use these...
Motor to Speed Change Unit: 4L270 <<<-Click to view belt
Speed Changer to Wash Drum Pulley 4L430 <<<-Click to view belt
New belts will require a belt adjustment as outlined in the service manual.
Opps edit, I just realized you meant the Dryer (D8)...
Motor to Idler 3L380
Idler to Basket 3L420
This post was last edited 04/17/2019 at 16:03
Post# 1030149 , Reply# 2   4/17/2019 at 19:53 (1,825 days old) by Northwesty (Renton, WA)
I
did to to an auto parts store to replace mine once. Seems like they might have been a little wider... but they worked.
Post# 1030198 , Reply# 3   4/18/2019 at 11:52 (1,825 days old) by bellalaundry (St. Catharines, Ontario, Canada)
Thanks Robert
I've ordered them, and you made it so easy including the links! Have a great Easter weekend!
Guy
Post# 1030210 , Reply# 4   4/18/2019 at 15:45 (1,825 days old) by sfh074 ( )
I always get mine from D&D on fleabay. Great quality.
Less expensive too...
https://www.ebay.com/itm/D-D-PowerDrive-...
He also has most of them in the kevlar wrapped cloth as well which makes for less wear, less rubber dust and runs quieter as well!
Post# 1031219 , Reply# 5   4/29/2019 at 13:22 (1,814 days old) by bellalaundry (St. Catharines, Ontario, Canada)
Thanks again Robert!
The belts just arrived, and they were a perfect fit! The dryer seems quieter now, too!
Guy
Post# 1031222 , Reply# 6   4/29/2019 at 13:52 (1,814 days old) by Unimatic1140 (Minneapolis)
Yay! Glad it worked well Guy, happy quieter drying!
