Thread Number: 79300
/ Tag: Wanted to Buy Items
Should I buy this coppertone Frigidaire refrigerator? |
Post# 1032292 , Reply# 1   5/10/2019 at 10:29 (1,805 days old) by RP2813 (Sannazay)   |   | |
Post# 1032298 , Reply# 2   5/10/2019 at 11:16 (1,805 days old) by mrcoppertone (Los Angeles)   |   | |
It is for sale for zero dollars! |
Post# 1032308 , Reply# 3   5/10/2019 at 13:17 (1,805 days old) by norgeway (mocksville n c )   |   | |
BUT if you like it you can bet its 10,000 times better than anything built today, |
Post# 1032316 , Reply# 5   5/10/2019 at 14:43 (1,805 days old) by pulltostart (Mobile, AL)   |   | |
Post# 1032318 , Reply# 6   5/10/2019 at 14:55 (1,805 days old) by pdub (Portland, Oregon)   |   | |
This is a manual defrost model. It is in VERY good shape for its age. I would definitely take it if I were you.
I recommend moving it in an upright position if at all possible. I moved one on its side once and even after letting it sit upright for 24 hours before plugging in, the compressor died. So don't take a chance. Best of luck. |
Post# 1032321 , Reply# 7   5/10/2019 at 15:56 (1,805 days old) by goatfarmer (South Bend, home of Champions)   |   | |
That's about a 1968 model Frigidaire. Should have a "N" in the model number, something like FD 141 TN or similar. That one still has the model number stamped on the back. Cycle defrost, not a frost free. I wouldn't hesitate to use this as a daily driver 'fridge. No fans, or defrost systems to worry about. Go for it! |
Post# 1032329 , Reply# 8   5/10/2019 at 18:00 (1,805 days old) by mrcoppertone (Los Angeles)   |   | |
Thanks for the advice everyone. This sounds like a go to me. How does the cycle defrost work? Does it have some kind of dial, turn off on its own, or do you unplug with the door open? |
Post# 1032332 , Reply# 9   5/10/2019 at 18:43 (1,805 days old) by RP2813 (Sannazay)   |   | |
I think the "cycle defrost" is similar to GE's, where the evaporator coil/plate in the rear of the fresh food section does defrost, but the freezer section doesn't. Defrosting occurs each time the compressor cycles off. The compressor remains off until the coil/plate in the fresh food section reaches a certain temperature, signaling that the condensation has melted and drained away.
The freezer must be defrosted manually. Either turn the cold control to the "OFF" position or unplug the fridge, then let the freezer defrost. There are portable defrost heaters that help speed the process (see picture). It doesn't look like there's a drain in the freezer section, which is a real drawback IMO because that means sopping up all of the water. GE provided a drain, so a simple wiping down is all that's required. All told, the hands-on portion of defrosting the GE totaled about ten minutes.
A new freezer door gasket made a huge difference on my GE. I went from defrosting every three or four months to less than twice a year. |
Post# 1032399 , Reply# 10   5/11/2019 at 17:21 (1,804 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This could be an excellent ref for you if the sealed refrigerating system is working properly.
I would not replace the gasket unless you can find an exact replacement that is in good pliable condition AND only if it is truly not sealing properly, you will know if it is leaking because you will get fast frost build-up on the ceiling of the freezer. Otherwise just clean up the old seal without removing it.
Best way to defrost is to put one or two fairly large pots of boiling water in the freezer after turning the temperature dial in the ref section off. [ the food in the ref section can stay put as defrosting should only 1/2 - 3/4 of an hour ]
I would NOT use an electric defroster because I have seen many older refs destroyed by these and it is not nearly as fast and is a bigger mess than the pots of boiling water.
Also DO-NOT use anything metal to try and scrape loose the frost, this FD ref uses a roll-bond aluminum evaporator and even a blunt butter knife can puncture the evaporator and immediately destroy the refrigerator [ if you want you can use a plastic windshield scraper ]
Post# 1032411 , Reply# 12   5/11/2019 at 21:38 (1,804 days old) by fan-of-fans (Florida)   |   | |
I like it. The detailing is very nice, and it's in remarkable condition and clean for its age! Good find. |
Post# 1032423 , Reply# 13   5/11/2019 at 22:46 (1,804 days old) by norgeway (mocksville n c )   |   | |
YES These are WONDERFUL |
Post# 1032963 , Reply# 15   5/18/2019 at 11:33 (1,797 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Model number should also be behind the kick plate or crisper drawers.
I've had limited success with putting something behind the gasket, a filler of sorts. Maybe a small piece of foam? This post was last edited 05/18/2019 at 12:08 |
Post# 1032966 , Reply# 16   5/18/2019 at 12:24 (1,797 days old) by oliger (Indianapolis, Indiana)   |   | |
The quickest and easiest way for me to defrost the freezer is to turn it off and put a pan of boiling water on top of a towel and close the door. |
Post# 1032988 , Reply# 17   5/18/2019 at 17:11 (1,797 days old) by pulltostart (Mobile, AL)   |   | |
Post# 1033001 , Reply# 18   5/18/2019 at 21:12 (1,797 days old) by spacepig (Floridas Emerald Coast)   |   | |
Post# 1033124 , Reply# 20   5/19/2019 at 15:17 (1,796 days old) by hippiedoll ( arizona )   |   | |
Post# 1033125 , Reply# 21   5/19/2019 at 15:18 (1,796 days old) by RP2813 (Sannazay)   |   | |
I've provided a link to a site that offers all types of refrigerator door gaskets. Instead of going by make and model, it shows the design of the gasket (cut-away side view) and you pick what matches yours. You can order a cheap collection of samples to match up.
You can try repairing the gasket with silicone, but since it's the freezer, you really do need a tight seal all the way around in order to reduce the frequency of defrosting. Repair may not be enough.
The good thing is that it's much easier to replace the gasket on the freezer door than on the fresh food door. It's a more manageable size and you don't need to tilt the fridge back like you would in order to get at the bottom portion of the gasket on the fresh food door. CLICK HERE TO GO TO RP2813's LINK |
Post# 1033128 , Reply# 22   5/19/2019 at 15:45 (1,796 days old) by LowEfficiency (Iowa)   |   | |
Post# 1033231 , Reply# 23   5/20/2019 at 15:23 (1,795 days old) by mrcoppertone (Los Angeles)   |   | |
RP2813, that's a great resource. Will go ahead and order some swatches. I think you're probably right that a repair won't do an adequate job. |
Post# 1033411 , Reply# 24   5/22/2019 at 19:18 (1,793 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
I just picked up a 1964 Frigidaire Imperial. Replacing gaskets can be a pain. Here's another resource, but they specializes in antique appliance restoration from the 1920-1950's. But who knows, they might be of help anyways. CLICK HERE TO GO TO ovrphil's LINK |
