Thread Number: 79352
/ Tag: Vintage Dryers
belt replacement Frigidaire dryer |
Post# 1032702 , Reply# 1   5/15/2019 at 12:21 (1,806 days old) by washdaddy (Baltimore)   |   | |
the dryer was made somewhere in the early 90's the model # is FDGB23RGS1 serial # is XD03914409 |
Post# 1032705 , Reply# 2   5/15/2019 at 12:54 (1,806 days old) by coldspot66 (Plymouth, Mass)   |   | |
The ribbed side of the belt gets wrapped around the motor pulley. The ribbed side goes against the drum surface. |
Post# 1032731 , Reply# 4   5/15/2019 at 19:29 (1,806 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This dryer was either built in 1990 or in 2000, Be sure with a dryer this old to check and at least lucubrate the rear drum bearing and also check the front drum bearing for excessive wear, usually by the time the belt breaks on one of these dryers other work is required to keep it running safely and well.
FD sells a kit the includes the F&R drum bearings, the belt and an idler pulley, this kit is usually your best parts buy to keep the dryer in good shape.
