Thread Number: 79353
/ Tag: Vintage Dryers
Maytag DG806 |
Post# 1032711   5/15/2019 at 15:26 (1,806 days old) by floyde (Los Angeles, CA)   |   | |
I have a 1979 dryer and would like to get a new belt. Does anyone have a model number of the belt I could order? Thank you! |
Post# 1032715 , Reply# 1   5/15/2019 at 16:05 (1,806 days old) by coldspot66 (Plymouth, Mass)   |   | |
If this is a halo of heat dryer it uses 2 belts...Y311013 & Y 311012. They are still available. |
Post# 1032748 , Reply# 2   5/15/2019 at 22:24 (1,806 days old) by Maytag85 (Sean A806)   |   | |
Post# 1032749 , Reply# 3   5/15/2019 at 22:24 (1,806 days old) by floyde (Los Angeles, CA)   |   | |
It’s 1979 so large drum anyone know? |
Post# 1032750 , Reply# 4   5/15/2019 at 22:30 (1,806 days old) by Maytag85 (Sean A806)   |   | |
Your Maytag DG806 from 1979 has the larger drum, and the Maytag Halo Of Heat gas dryers built before the stream of heat dryers had a standing pilot that had to be lit so the burner would come on, and the newer stream of heat dryers have a igniter and you will see it glow ping when you turn the dryer on.
Post# 1032751 , Reply# 5   5/15/2019 at 22:37 (1,806 days old) by Maytag85 (Sean A806)   |   | |
Post# 1032752 , Reply# 6   5/15/2019 at 22:57 (1,806 days old) by floyde (Los Angeles, CA)   |   | |
Anyone know. |
Post# 1032755 , Reply# 7   5/16/2019 at 00:59 (1,806 days old) by LowEfficiency (Iowa)   |   | |
>> What does this have to do with my question of a belt
Hi floyde, the problem is that you asked for a belt for a dryer that doesn’t exist! The Halo-of-Heat DE/DG806 was only produced until around 1976. The Stream-of-Heat dryers were then produced until around 1980. So something is wrong, either your year (1979), or your model (DG806). Perhaps instead of a DG806, you have a DG608? Or a DG808? |
Post# 1032767 , Reply# 8   5/16/2019 at 07:05 (1,806 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes thank you Dave, MT 806 dryers have two belts and MT808 dryers have one, they are COMPLETELY different dryers, this is why exact model #s are so important.
In either case the belts are still readily available,
Question why do you think it needs a belt, have you even taken it apart yet, at its age it is likley to need more than just a belt if you are trying to use this dryer much.
John |
Post# 1032769 , Reply# 9   5/16/2019 at 08:03 (1,806 days old) by oliger (Indianapolis, Indiana)   |   | |
8 replies and not a single answer! If you know for sure that your dryer is a 1979, this will work: www.partselect.com/PS1175... |
Post# 1032793 , Reply# 10   5/16/2019 at 12:17 (1,805 days old) by LowEfficiency (Iowa)   |   | |
That's because we care about giving the CORRECT answer. It avoids a lot of wasted time, money, and frustration to get the correct part the first time. And remember too that we are on a forum here. Resolving this confusion isn't just for floyde - others down the road will find this thread in their search results ("DG806 belt", etc). So resolving the ambiguity may prevent similar problems for others in the future. |
Post# 1032814 , Reply# 12   5/16/2019 at 14:40 (1,805 days old) by floyde (Los Angeles, CA)   |   | |
It is a DG808.. So I assume Y312959 is the correct belt? Many thanks, Can someone verify? |
