Thread Number: 79478
What parts do I need to replace? |
Post# 1033871   5/29/2019 at 14:15 (1,764 days old) by LawrenceMcLane (Texas)   |   | |
First time working on a belt drive Whirlpool Kenmore, something is broken on the wig wag and I have no clue what to look for online to buy. Any help? |
Post# 1033872 , Reply# 1   5/29/2019 at 14:26 (1,764 days old) by turquoisedude (.)   |   | |
It would seem that the plunger on the left is stuck in the solenoid coil; it may be possible to free it up with a spray of PB Blaster. The wig-wag assembly (also called the 'control magnet assembly' in older WP/Kenmore repair guides) may be replaced if necessary. Not sure of a current part number but I am sure other more knowledgeable folks here will chime in with that.
The good news - swapping out a wig-wag is not difficult. Even I have done it... LOL IF the plunger itself is broken or damaged, a replacement is available (I have that part number and a picture if you need it). |
Post# 1033874 , Reply# 2   5/29/2019 at 14:49 (1,764 days old) by LawrenceMcLane (Texas)   |   | |
turquoisedude, here is a better picture of the part, I spun the motor by hand and a piece separated. Here is also. Link to a video of it working.
Post# 1033876 , Reply# 3   5/29/2019 at 15:01 (1,764 days old) by turquoisedude (.)   |   | |
OK, that plunger is definitely broken! Here's what I bought last year to get my '65 Lady K running again. Looks like I got it from PartSelect.
It was a slight pain to replace, but not that bad!!
Post# 1033880 , Reply# 4   5/29/2019 at 15:47 (1,764 days old) by DADoES (TX, U.S. of A.)   |   | |
The wigwag has to come off to replace the plunger. Sometimes can be a challenge to get it loose. The sector gear shaft onto which the wigwag mounts is split and expands a bit to grip it when the bolt is tightened. You may consider pulling the transmission and cleaning/lubricating the cam bars. There's a compression spring that mounts atop the bars, behind the wigwag, to hold them down. |
