Thread Number: 79548
/ Tag: Vintage Dryers
57 Frigidaire Dryer Fan Puzzle! |
Post# 1034544   6/5/2019 at 10:52 (1,780 days old) by Marks (Tucker, GA)   |   | |
Hi Everyone,
Does any literature exist or does anyone know what the fan set up in an airflow (not the more common filtrator) Frigidaire dryer looks like? Is it a blade fan or a cage fan? This is the fan shroud, and unfortunately this dryer was moror-less upon arrival, but this is the motor and fan I found. If this is the correct fan, I will just have to modify the propeller shaft length, but if this had a cage fan, I’ll have to find one that fits AND modify the propeller shaft!!! Old machines are never easy! |
Post# 1034563 , Reply# 1   6/5/2019 at 13:30 (1,780 days old) by cfz2882 (Belle Fourche,SD)   |   | |
That housing would use a radial flow,"centrifugal" type impeller-but not "squirrel cage"-that style will plug with lint.Original fan was probably bakelite with slightly curved radial blades.A GE fan might work-fits a 1/2" shaft-but not sure if GE is correct rotation. |
Post# 1034576 , Reply# 2   6/5/2019 at 15:22 (1,780 days old) by Marks (Tucker, GA)   |   | |
Post# 1034597 , Reply# 3   6/5/2019 at 18:36 (1,780 days old) by cfz2882 (Belle Fourche,SD)   |   | |
the one I'm thinking of was used in GE dryers ~1960s-mid 90s era,some of the modern replacements of this are yellowish nylon instead of black bakelite.Looks like GE fan is correct rotation for the Frigidaire.I'll look in my spares stash to see if I have one handy to measure up. |
Post# 1034609 , Reply# 4   6/5/2019 at 20:44 (1,780 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1034633 , Reply# 5   6/6/2019 at 13:19 (1,779 days old) by Marks (Tucker, GA)   |   | |
Post# 1035035 , Reply# 6   6/10/2019 at 19:44 (1,775 days old) by Marks (Tucker, GA)   |   | |
Post# 1035041 , Reply# 7   6/10/2019 at 20:11 (1,775 days old) by Marks (Tucker, GA)   |   | |
I also came across this, but not sure if it’s even remotely close
Post# 1035055 , Reply# 8   6/10/2019 at 23:21 (1,775 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
