Thread Number: 79677
Speed Queen NA3311-3062 - Water Fill Does Not Stop at Proper Level |
Post# 1035766 , Reply# 1   6/20/2019 at 05:40 (1,770 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
First question, does it stop filling when you unplug it?
If it doesn’t stop filling when you unplug it you have a bad inlet valve beyond that you probably have a bad pressure switch unless you have a leak in the air don tubing that goes from the outer tub to the pressure switch or a clog in that tube. John |
