Thread Number: 79812
/ Tag: Classified Ad Finds
Tappan Mid-Century Vintage Dishwasher - $25 (Austin) TX With the black drum |
Post# 1037079   7/3/2019 at 23:57 (1,751 days old) by 747xpanam (Palm Springs CA)   |   | |
It's the Tappan with the black drum barrel! Post id: 6923793501 Hope someone can save this!The inside door looks new! On my Iphone i can't post pictures sorry. |
Post# 1037084 , Reply# 2   7/4/2019 at 00:51 (1,751 days old) by 747xpanam (Palm Springs CA)   |   | |
Thanks bigalsf. |
Post# 1037092 , Reply# 3   7/4/2019 at 04:50 (1,751 days old) by chachp (North Little Rock, AR)   |   | |
Post# 1037095 , Reply# 4   7/4/2019 at 06:27 (1,750 days old) by turquoisedude (.)   |   | |
Post# 1037096 , Reply# 5   7/4/2019 at 06:27 (1,750 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Wow, haven't seen one of these in a long time, we would love to give it a proper home in our wall of dishwashers at the museum.
This DW was an interesting exercise in engineering, but from our actual use testing it was easily the poorest performing DW ever built in the US during the 2nd 1/2 of the 20th century.
If someone wants to help save it I will pay reasonable shipping, recoverey costs.
Post# 1037097 , Reply# 6   7/4/2019 at 06:29 (1,750 days old) by turquoisedude (.)   |   | |
Post# 1037110 , Reply# 7   7/4/2019 at 10:26 (1,750 days old) by appnut (TX)   |   | |
Post# 1037111 , Reply# 8   7/4/2019 at 10:35 (1,750 days old) by appnut (TX)   |   | |
Post# 1037117 , Reply# 9   7/4/2019 at 11:31 (1,750 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It had two detergent cups, the first wash would rinse the detergent out or either the right or left cup [ I can't remember which direction it washed first.
Then it would drain & refill and wash the other direction using the detergent in the other side of the dispenser cup.
After the wash drained the DW would do two rinses, one in each direction.
Post# 1037118 , Reply# 10   7/4/2019 at 11:46 (1,750 days old) by peteski50 (New York)   |   | |
Family friends of ours had the TOL model with the night light and the separate roll out top rack. It was quiet DW for the era but they rinsed everything first so I never knew what the real performance was. Theirs was just like the picture except they had it in yellow! I remember the dial light up and when it was drying it sounded like some type of fan going.
Post# 1037209 , Reply# 11   7/5/2019 at 06:24 (1,749 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1037212 , Reply# 12   7/5/2019 at 07:12 (1,749 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1037223 , Reply# 13   7/5/2019 at 12:23 (1,749 days old) by norgeway (mocksville n c )   |   | |
Im so glad you got it John!! I cant wait to see it!!! |
Post# 1037230 , Reply# 14   7/5/2019 at 13:40 (1,749 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 1037236 , Reply# 15   7/5/2019 at 15:08 (1,749 days old) by appnut (TX)   |   | |
No, this was a purely Tappan Design. It's originally from the early 1960s late 1950s. The house we bought in fall of 1961, built up to a year earlier, had the same dishwasher, but it had the O'Keefe & Merrit brand label. My dad opted to have the Waste King moved to the new house and the dishwasher in the new house went to our old house. |
Post# 1037237 , Reply# 16   7/5/2019 at 15:14 (1,749 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 1037238 , Reply# 17   7/5/2019 at 15:18 (1,749 days old) by appnut (TX)   |   | |
Post# 1037266 , Reply# 18   7/5/2019 at 21:02 (1,749 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
This post was last edited 07/05/2019 at 22:11 |
Post# 1037273 , Reply# 19   7/5/2019 at 23:18 (1,749 days old) by 747xpanam (Palm Springs CA)   |   | |
Glad you saved it.I would love to see the DW wall of fame sometime! |
Post# 1037294 , Reply# 20   7/6/2019 at 08:15 (1,748 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1037298 , Reply# 21   7/6/2019 at 10:02 (1,748 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Austin, This DW had a 8-9"black Bakelite drum running from front to back of the bottom of the DW, it rotated at 1,725 RPMs, the motor was inside the drum which was installed from the rear of the DWs tank, if you needed to access the motor you have to remove the machine from its installed position.
The spinning drum would fling water either to the left or right depending which direction the drum was turning. There was no filter of any kind and it did a miserable job of cleaning, We had one about 30+ years ago and tried it out and the result was terrible, When CRs tested it it was about the worst DW they had ever tested, probably its one claim to fame was it was reasonably quiet. John L. |
Post# 1037302 , Reply# 22   7/6/2019 at 10:22 (1,748 days old) by peteski50 (New York)   |   | |
Post# 1037311 , Reply# 23   7/6/2019 at 13:15 (1,748 days old) by norgeway (mocksville n c )   |   | |
Like concealed bake units under the oven floor, that LOOKED good on paper but just didn't work. |
Post# 1037316 , Reply# 24   7/6/2019 at 13:41 (1,748 days old) by appnut (TX)   |   | |
At the back of the Bakelite drum, there were blades that fanned out from the center to the edge that helped cause the water to be turbulent enough to rise out and over the dishload. The water wasn't just simply being thrown out and over from the drum edge as it spun at the 1725 rpm speed. I was anywhere from 9-11 or 12 the times I was around my Godfather's house that had one of these. I don't remember what the exact increment each timer advance was. Probably every 30 or 45 seconds. I don't think it was an entire 60 seconds. Anyway, the motor would rotate the drum for like 1 or 2 timer increments. Then pause for one increment and then rotate in the opposite direction for the same number of increments. The timer dial had regular wash, short wash, rinse & dry, and plate warmer sections on it. I don't remember if it had a separate Rinse & Hold cycle. The drum also rotated at normal speed during dry to create some sort of moving air currents. |
Post# 1037395 , Reply# 25   7/7/2019 at 06:48 (1,747 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1037406 , Reply# 26   7/7/2019 at 09:50 (1,747 days old) by norgeway (mocksville n c )   |   | |
The drum was stationary It just spun in different directions |
Post# 1037412 , Reply# 27   7/7/2019 at 11:31 (1,747 days old) by appnut (TX)   |   | |
Austin, just my personal opinion, but I considered this dishwasher, as well as Frigidaire's Spin Tube to be the worst dishwashers every produced, except for the Apex from late 1940s that had just a wash and a rinse (and my parents had the Apex). The only thing the Frigidaire had going for it was more capacity. Keep in mind, for most people buying new houses that did come equipped with a dishwasher, it was their first dishwasher and everyone welcomed have some sort of automation. As I reflect back on every house on our street that I did get to go into when I was little, the houses that had gas kitchens either had KitchenAid, Waste King dishwashers or the D&M produced BOL Whirlpool impeller dishwasher. Our kitchen was the exception being "bestowed" with this dishwasher. Our builder built another house on our street and even that kitchen had the Whirlpool. The house on one side of us that had a gas kitchen, complete with a smilar O'Keefe & Merritt cooktop & the same wall oven, also had the Whirlpool. The rest of the houses on the street had all electric kitchens that were either GE, Frigidaire, or Westinghouse and had the matching dishwasher. |
Post# 1037425 , Reply# 28   7/7/2019 at 15:32 (1,747 days old) by ozzie908 (Lincoln UK)   |   | |
Thank you for clearing that up sounds a bit like the awful Colston spin tube dishwashers we had back in the 60's they were awful the wash results were not that good and if you washed everything first why bother having a DW in the kitchen? I think they had the name if Jetstream but the only place you ever saw a jet was out the door seal...
Austin |
