Thread Number: 80007
/ Tag: Vintage Dishwashers
KitchenAid Dishwasher drying fan not working |
Post# 1039242   7/24/2019 at 00:52 (1,730 days old) by Geextrarinse (Hudson Valley, New York )   |   | |
Just buzzes during the dry cycle. What should I do?! Any advice would be appreciated! Thanks !
Post# 1039400 , Reply# 1   7/25/2019 at 07:41 (1,729 days old) by Unimatic1140 (Minneapolis)   |   | |
Hey Matthew, nice to see you posting! I had that exact same problem on my KD-12 years ago when I first got it. The bearing in the fan is probably dry. What I did was to remove the heater/fan assembly and oil the fan bearing. Then I got the fan blades turning by manually turning the fan back and forth until it was loose and free. Then I hooked the fan up to a power cord on my work bench (leaving the heater out of the circuit) and let it run for a while. It worked and it's been running perfectly for over a decade after doing that.
Post# 1042114 , Reply# 2   8/18/2019 at 14:29 (1,705 days old) by Geextrarinse (Hudson Valley, New York )   |   | |
