Thread Number: 80274
Spin issues with the '51 Frigidaire WO-65 |
Post# 1042229   8/19/2019 at 14:16 (1,711 days old) by turquoisedude (.)   |   | |
The '51 Unimatic has been sidelined for a couple of months now due to a severe case of the shakes... If I set a video to that Harry Belafonte tune "Jump In The Line" (with that line, 'Shake, Shake, Senora') it would have fit perfectly.
I had thought the problem was due to the bad flooring down in the Ogden laundry room so I hauled the Frigidaire out to the garage for some tinkering. Not good... The machine was level, too. |
Post# 1042230 , Reply# 1   8/19/2019 at 14:20 (1,711 days old) by turquoisedude (.)   |   | |
Amazingly, my first instinct was 'read the manual'... Sure enough, a leading cause for what the Frigidairians of the day described as "excessive vibration" was a glazed snubber plate.
Well, that's where I started! The snubber plate sure looked glazed to me. As directed in the manual, I cleaned both surfaces with fine sandpaper. I wiped down the cleaned surfaces with bit of varsol (a pearl of wisdom I gleaned from an old thread on Frigidaire service). I even managed to get the crossbrace at the base of the washer back into place with a minimum of swearing! |
Post# 1042231 , Reply# 2   8/19/2019 at 14:21 (1,711 days old) by turquoisedude (.)   |   | |
Post# 1042232 , Reply# 3   8/19/2019 at 14:24 (1,711 days old) by turquoisedude (.)   |   | |
I had to try at least one test with water. I think I've fixed it now!
The real test is going to be with a load of laundry down in the basement, however. IF the washer still shakes too much in it's 'slot', Phil has given me an idea on how to firm up the floor. Now you all understand why I told real estate agents when we were looking for a house "No finished basement? No problem" LOL |
Post# 1042239 , Reply# 4   8/19/2019 at 15:51 (1,711 days old) by Unimatic1140 (Minneapolis)   |   | |
I sure hope the snubber and pump plate was the issue Paul, however... the problem with Unimatic washers with vibrations is most likely is caused by the rubber mechanism support becoming hardened with age. Unfortunately there is no great cure for this except to find a support that is in better condition. The harder the rubber the more vibration the machine has. When these supports were new the Unimatic washers were amazingly stable.
Post# 1042295 , Reply# 7   8/20/2019 at 07:25 (1,710 days old) by turquoisedude (.)   |   | |
Post# 1042297 , Reply# 8   8/20/2019 at 07:34 (1,710 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 1042299 , Reply# 9   8/20/2019 at 07:42 (1,710 days old) by Unimatic1140 (Minneapolis)   |   | |
I'm sure making reproducing the support can be done Bud, and it would be an amazing to have that part new, but it has to be done carefully with testing. That support has multiple functions including the water boot seal for the outer tub, snubber and keeping the tub center. It also has two metal plates embedded into the rubber one at the top and one at the bottom. Too stiff rubber will cause vibration or too loose rubber will cause gyroscopic motions that can cause the tub to hit the outer tub at 1140rpm continuously. There also has to be no possibility of the rubber ripping as it could set up a possible dangerous situation.
Post# 1042332 , Reply# 11   8/20/2019 at 16:32 (1,710 days old) by Tomturbomatic (Beltsville, MD)   |   | |
YAY! YIPPIE! HOORAY!!!! Thank you, thank you, thank you from someone who can't make anything but trouble! |
Post# 1042335 , Reply# 12   8/20/2019 at 16:45 (1,710 days old) by sfh074 ( )   |   | |
I've noticed! .... lol, jk |
Post# 1042364 , Reply# 13   8/20/2019 at 23:31 (1,709 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
