Thread Number: 80672
/ Tag: Vintage Dryers
Roper Top Filter Gas Dryer Testing |
Post# 1046445   9/30/2019 at 14:29 (1,640 days old) by stricklybojack (South Hams Devon UK)   |   | |
It’s tumbling but no heat. Thermal fuse and thermostats show continuity. The igniter reads 83, a little low. (50-400) The coils test well, except the three prong reads 569 on the outer two terminals. (300-2000) Still within spec but... What would you do? |
Post# 1046464 , Reply# 1   9/30/2019 at 18:35 (1,640 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Is there voltage at the gas burner ? if yes
Does the igniter heat ? If no the heat sensor is probably open.
If the igniter heats and cycles off on the heat sensor in about a minute you have a bad set of valve coils, Replace valve coils.
There is a very small chance you have a bad gas valve, although this seldom happens on a WP built dryer, 90% of the bad gas valves we see are on MT dryers.
Also I am assuming you have gas at the valve assembly.
