Thread Number: 81159
/ Tag: Member Selling Item(s)/Non Professionally
Maytag A207 for Sale |
Post# 1164212 , Reply# 1   11/18/2022 at 13:38 (522 days old) by amml (Canada)   |   | |
Hi, where did you find the timer motor? My Maytag washer is the same model, needing a Kingston Model 60 motor, with 11 teeth on the gear. (the gear is fine, no power in the motor) Thoughts? Thanks |
Post# 1164213 , Reply# 2   11/18/2022 at 14:03 (522 days old) by qsd-dan (West)   |   | |
We'll need the timer part#. There's 5 different timers for this model (more including suds saving models) but it's probably going to be a 204454 timer with a 204663 timer motor.
https://www.ebay.com/itm/115331414129QUE... |
Post# 1164242 , Reply# 3   11/18/2022 at 19:11 (522 days old) by amml (Canada)   |   | |
Thank you, I'll need to take the top off to find the timer part number.... |
Post# 1164469 , Reply# 4   11/21/2022 at 13:19 (519 days old) by amml (Canada)   |   | |
I've taken a photo of what might be the timer number? Is this legible enough? (yes, backwards) I can't move the washer, please let me know where I might find any other number you need if this is not sufficient info.
Post# 1164470 , Reply# 5   11/21/2022 at 13:23 (519 days old) by qsd-dan (West)   |   | |
Just as I suspected, it's a 204454 timer. This is the timer motor you need.
Post# 1164472 , Reply# 6   11/21/2022 at 14:14 (519 days old) by amml (Canada)   |   | |
Thank you! |
Post# 1168367 , Reply# 7   1/5/2023 at 12:09 (474 days old) by amml (Canada)   |   | |
@ qsd-dan, ordered and received the timer motor, washer works fine. Thank you! |
Post# 1168374 , Reply# 8   1/5/2023 at 14:09 (474 days old) by qsd-dan (West)   |   | |
