Thread Number: 81243
Vintage Apt sized dryer |
Post# 1052609 , Reply# 1   11/28/2019 at 13:15 (1,603 days old) by twintubdexter (Palm Springs)   |   | |
...calling that very nice motorhome "vintage". You make very old people like me feel even older
This one qualifies as vintage...
Post# 1052632 , Reply# 2   11/28/2019 at 19:27 (1,602 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi, These are very good dryers, This dryer was built the 20th week of 1977, it needs 208-240 volts to power the heater, you could run it on 120 volts however the heater is just 3,200 watts on 240 volts which means that it will only put out 800 watts on 120 volts.
Note, there is no such thing as 110 or 220 volts in the US any longer.
If you really want to run it on 120 volts you can get a 1,400 watt heater from a 120 volt version of this dryer which will speed it up a good bit over just 800 watts. |
Post# 1052689 , Reply# 3   11/29/2019 at 10:38 (1,602 days old) by vacerator (Macomb, Michigan)   |   | |
A GMC motorhome is indeed vintage. It's over 25 years old. Is not an Olds Toronado of that year vintage also? They share drivtrains and engines. |
Post# 1052692 , Reply# 4   11/29/2019 at 10:44 (1,602 days old) by twintubdexter (Palm Springs)   |   | |
Post# 1052720 , Reply# 5   11/29/2019 at 15:26 (1,602 days old) by RP2813 (Sannazay)   |   | |
Post# 1052735 , Reply# 6   11/29/2019 at 19:25 (1,601 days old) by twintubdexter (Palm Springs)   |   | |
