Thread Number: 81315
Another Maytag enters the stable. |
Post# 1053380   12/6/2019 at 19:41 (1,601 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Picked it up this afternoon. A702 / 216858QT Owner said it wouldn't agitate. We will see. |
Post# 1053382 , Reply# 1   12/6/2019 at 19:43 (1,601 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Should be a decent match for this dryer I acquired a few years ago. |
Post# 1053383 , Reply# 2   12/6/2019 at 19:46 (1,601 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1053384 , Reply# 3   12/6/2019 at 19:47 (1,601 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1053481 , Reply# 4   12/7/2019 at 20:52 (1,600 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 1053530 , Reply# 5   12/8/2019 at 06:09 (1,600 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1053608 , Reply# 6   12/8/2019 at 17:22 (1,599 days old) by hippiedoll ( arizona )   |   | |
That's an OLDIE BUT GOODIE Maytag match you have there! I'm not familiar with the older Maytags. What year would these be from, I'm guessing they are early 60's? I am more familiar with the later Center-dial Maytag models from the late 60's-70's, but far from being an expert!
:oD CONGRATULATIONS on your find Kenny! I'm glad you found a matching washer for the dryer you have. I can't wait to read your progress and see this matched pair, up and running! WOOOO HOOOO! :oD |
Post# 1053702 , Reply# 7   12/9/2019 at 16:55 (1,598 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1053717 , Reply# 8   12/9/2019 at 19:12 (1,598 days old) by qsd-dan (West)   |   | |
702's were a 2 year only production run, 1964-1965. It's the #1 pre 1966 washer I'd recommend. Other than being TOL and with lots of flexibility, it has the beefier suspension design and at 45 seconds, has the longest spray rinse Maytag offered until 1966.
Keeping my fingers crossed the agitation issue isn't a sized upper shaft. Porcelain tub wear looks like low use or they were smarter than the average bear when it came to properly loading the washer. The dryer look like a '60/'61 641C. It's basically a D700 with a different front panel. As far as matching, close enough for government work ;) |
