Thread Number: 81489
General Electric Filter Flo - Leaks from bottom of tub |
Post# 1055274 , Reply# 1   12/23/2019 at 19:08 (1,577 days old) by bradfordwhite (central U.S.)   |   | |
Have you removed the back and looked inside to see where the water is coming from?
It could be the main boot/seal has simply come loose or the stainless steel clamps that hold it on have rusted off. This is my main estimate. If this is the case you may need to get the new clamps or simply reinstall whats in there with stainless steel bolts.
1. Could be the boot seal
2. could be rust through of the tub
3. could be the drain tube from the tub is leaking or rotted.
The big deal is going to be removing the tub and gaining access to the seal.
Send in some pics as you progress.
This post was last edited 12/23/2019 at 20:28 |
Post# 1055276 , Reply# 2   12/23/2019 at 19:15 (1,577 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
it is entirely possible that the washer experienced a severely out of balance spin and broke the seal of an old tub boot but, having rebuilt a handful of these machines, it is rare to find that is the only issue. These machines are typically rust-prone and there could be a number of places that spawn a leak. Since you’re going to be pulling the agitator and basket out, I’d plan on doing a good cleaning and rust-proofing. Beware of some new boots as they are not as flexible and will not seal. I’ve actually found old boots, even used ones, work better after a good soak and clean. I typically replace the outer tub gasket that goes on the top rim of the outer tub while I’m at it.
Post# 1055307 , Reply# 4   12/23/2019 at 21:38 (1,577 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 1055420 , Reply# 5   12/24/2019 at 18:37 (1,576 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1055434 , Reply# 6   12/24/2019 at 22:05 (1,576 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Zachery, I would take the washer apart before spending money on parts, there is a good chance that no parts are needed OR the machine may be a basket case.
All kinds of problems can surface just trying to get the washer apart, the good news is there are lots of parts out there for these machines.
Let us know what you find wrong.
Post# 1055450 , Reply# 8   12/24/2019 at 23:59 (1,576 days old) by Yogitunes (New Jersey)   |   | |
Post# 1055461 , Reply# 9   12/25/2019 at 02:28 (1,576 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
I’ve rebuilt a few if these machines and taken many pictures along the way. This thread I did last year and might be helpful.
CLICK HERE TO GO TO jons1077's LINK |
Post# 1055538 , Reply# 10   12/25/2019 at 17:49 (1,576 days old) by Moonshiner180 (Missouri)   |   | |
Okay, tinkering with it a little, got the lid open. Tips on getting the agitator out with household items/basic tools? Or is 2x4 and rope with a screwdriver as per the video really the best option?
Post# 1055546 , Reply# 11   12/25/2019 at 19:20 (1,575 days old) by Moonshiner180 (Missouri)   |   | |
Got the agitator off, now need a wire brush which I don't have at the moment.. bolts look pretty rusty. The top lip of the drum however is pretty clean except for one spot, nothing a little sandpaper and some Rust-Oleum can't take care of.
Post# 1055547 , Reply# 12   12/25/2019 at 19:29 (1,575 days old) by bradfordwhite (central U.S.)   |   | |
You got quite far. Once you get these three bolts removed you will be able to lift this HEAVY tub basket out and you'll have access to ...... whatever is leaking.
It is heavy and porcelain. You don't want to chip or drop the tub so have card board or something clean able but reasonably soft to set it on.
Thanks for the pictures.
Post# 1055586 , Reply# 15   12/26/2019 at 04:48 (1,575 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1055603 , Reply# 16   12/26/2019 at 08:33 (1,575 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yay glad you got it running without too much trouble, it is often amazing what we can do when we make the effort and tear into something that we may know little about, I love learning new stuff which I still love fixing appliances. Almost every day I learn new things, this occupation is anything but routine.
I hope you get a lot of good use out of this washer and you and your family have a great New Year.
Post# 1055638 , Reply# 18   12/26/2019 at 15:13 (1,575 days old) by hippiedoll ( arizona )   |   | |
I'm so happy for you that you got your vintage GE Filter-Flo washer leak figured out & fixed and that it is now up & running!
I think it's so cool that you could fix it yourself. I wish I was more mechanically-inclined, to be able to do repairs but unfortunately I'm not. So it amazes & elates me every time I see a vintage washer/appliance given a 2nd life! :o) WOOOO HOOOOO!! (Doing the HAPPY-DANCE for you on this side of the computer) :oD |
Post# 1055642 , Reply# 19   12/26/2019 at 16:37 (1,575 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Moonshine-----Congrats on success with a fine machine! Good work pays off, and Filter-Flo's are workhorse machines that wash well, rinse well, have plenty of options, etc. I've had various Kenmores, Whirlpools, Maytags, Norge, Hoover, Speed Queens thru the years, some with great success and some that just didn't "fix up" very well. I want to keep them all, but if I had to choose only one machine for some house that just doesn't have space for my 7, I would keep the workhorse 79 GE Filter Flo. 2 speeds, extra rinse when needed(rarely), great filtering and extraction, etc. Umm, quite a bit of water but I can't complain when I see the results.
HippieDoll-----always kind and positive comments, you are a favorite here, for me to read! Thank you! |
Post# 1055712 , Reply# 20   12/27/2019 at 12:30 (1,574 days old) by hippiedoll ( arizona )   |   | |
Post# 1055733 , Reply# 21   12/27/2019 at 16:37 (1,574 days old) by Doug (West Virgina)   |   | |
I want this machine when you’re done with it LOL ! Nice find, I looked for years for this model of filter flo an I finally found it on Craigslist about 5 years ago
