Thread Number: 81623
little 24” monster |
Post# 1056417   1/3/2020 at 18:31 (1,573 days old) by JohnBee (USA, NY)   |   | |
I had a trip to my husbands family in Georgia and I realized that everyone is in love with their old style agitator top loader.
They claim capacity While I was there I run a full load of 8 bath towels. Today I can prove that a small 24” front loader can handle more ! Btw we live in NYC and there’s absolutely no space for a full size washer. Even having a washer is kinda a luxury here Check the following pics . 7 bath towels 7 hand towels and 8 wash cloths |
Post# 1056419 , Reply# 1   1/3/2020 at 19:40 (1,573 days old) by bradfordwhite (central U.S.)   |   | |
People in the UK whose homes are often basementless and smaller in general than what we have in the U.S., will typically have a 24" space under their kitchen counters for a washer.
They've been getting on quite fine with such a washer for quite the while now. I had a 24" Maytag/Whirlpool washer I bought in 2015. It worked just great. No problems. |
Post# 1056421 , Reply# 3   1/3/2020 at 20:29 (1,573 days old) by RP2813 (Sannazay)   |   | |
John, you don't have to convince me! There is no way our king size comforter could fit in any size top load machine. Our Maytag Neptune front loader is small compared to most of today's front load machines, but the comforter fits in it.
I won't ever again have a top loader as my daily driver, even a vintage one that fills all the way, rinses thoroughly and uses truly hot water when desired. I've been using front load machines since 2007 and they are more efficient and better at cleaning.
My 1987 Maytag top loader is hooked up, but it sees little use. |
Post# 1056464 , Reply# 4   1/4/2020 at 09:21 (1,572 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 1056617 , Reply# 6   1/5/2020 at 15:39 (1,571 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
if for x reason i had to replace my 15 year old g1 whirlpool duet washer dryer set and could not afford the new frontload model beause they are 1 to costly or 2 had cycle i would not use i would go back to a topload washer mostly like in this set pic as an exemple with the matching dryer but so far after 15 years of use my g1 whirlpool duet washer is still going
Post# 1056665 , Reply# 8   1/6/2020 at 06:10 (1,570 days old) by ozzie908 (Lincoln UK)   |   | |
My washer and dryer are in the downstairs bathroom its in the corner where the hot water tank sat. There is a 13amp double outlet on the inside of the dividing wall its extremely difficult to access the plug due to the confinement of the space and its too far away to reach while in the shower, This was installed 2 years ago and is up to code as the whole house was rewired at the same time, I took a pic of my new washer its my logo.
Post# 1056666 , Reply# 9   1/6/2020 at 06:14 (1,570 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
In my previous apartment I had up to three washing machines and two dryers in the bathroom. Never had any problems with rust or electrical problems. I kept one washing machine in an unheated shed for a while, now that led to problems! The motor gut moisture on the inside and I guess it started rusting from inside. When I installed it and started using it after a few years, the motor gave a burning smell.
Post# 1056677 , Reply# 11   1/6/2020 at 07:32 (1,570 days old) by ozzie908 (Lincoln UK)   |   | |
The socket is not inaccessible it is difficult to change the plug but you can slide your hand down the gap to switch it off if you need to.
The electrics were all done by a reputable company here in Lincoln city and I too am aware that the distance between the washer and the shower are less than 3 meters but the difficulty to reach the power point while standing in the shower is practically impossible if you look at my picture the machine is in its corner the shower is to the right on the opposite wall. The Circuit breakers we have are so sensitive they trip at the slightest hint of earth leakage, I have no doubt someone will find something to complain about but me I am more than happy to not have my washer in the kitchen have always hated that. |
Post# 1056679 , Reply# 12   1/6/2020 at 08:21 (1,570 days old) by JohnBee (USA, NY)   |   | |
I've seen several new listings in New York City having the washer and the dryer installed next to the shower.
I would worry more about having a 230v dryer next to the shower rather a 120v washer. In my case it was all about space. I really had no space next to my kitchen sink. My heatpump dryer is located in the kitchen. I also don't like the idea having the machine next to the bathtub for several reasons. BUT having a washer installed and not having to take myself to the laudromat is amazing. :) FYI washer is connected on a GFCI outlet and always unplugged while not used. |
Post# 1056680 , Reply# 13   1/6/2020 at 08:28 (1,570 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1056701 , Reply# 14   1/6/2020 at 12:46 (1,570 days old) by JohnBee (USA, NY)   |   | |
Post# 1056720 , Reply# 15   1/6/2020 at 17:55 (1,570 days old) by iej (.... )   |   | |
120V or 230V will efficiently electrocute you in the shower if there's no RCD/GFCI and proper grounding. I wouldn't be more worried about either of them - they're both potentially lethal if not installed correctly. |
Post# 1056721 , Reply# 16   1/6/2020 at 18:19 (1,570 days old) by IowaBear (Cedar Rapids, IA)   |   | |
Many washers in the Midwest are located in old houses and unfinished basements without standpipes and just drain onto the floor, creating a big puddle of water on the floor around the drain. I grew up with one like this...as a little kid it was fun to watch. A neater approach is to have the washer drain into a washtub and have that drain more slowly into the floor drain.
The basement shower shared the floor drain so pausing the washer during a shower was a must. |
Post# 1056730 , Reply# 17   1/6/2020 at 20:16 (1,570 days old) by Rieon (Alberta, Canada)   |   | |
Post# 1056731 , Reply# 18   1/6/2020 at 20:16 (1,570 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Are nearly nonexistent with washers and dryers as these appliances are always permanently grounded through their power cords, in fact GFIs are not even recommended for these appliances.
In the US it would not make any difference whether the appliance is 240 volts or 120 volts, the shock potential to ground on a 240 volt dryer or electric range can never be more than 120 volts.
The only possible way you can get a 240 volt shock in the US is to get inside the appliance and touch the L1 and L2 wires at the same time, this will not happen even if you put the dryer in the shower with you, LOL
This is another reason why the 240 Volt GE Partio Carts were not any where near as dangerous as a string of Christmas lights as far as a possible shock hazard goes. The GE PC is permanently and completely grounded through the power supply cord, a few years ago we had a down poor durning cooking on one of our PCs and I didn't even turn it off, everything was still working and heating through the downpour.
Post# 1056740 , Reply# 20   1/6/2020 at 22:45 (1,570 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
In my previous apartment in Groningen I had a whole house GFI, but the dedicated laundry connection box was excluded from it. I sometimes had a washing machine running while showering. The laundry appliances were far away enough from the shower corner so you couldn't touch the washers. One was a bit closer I used an extension cord to run that, never did it while showering. The outlet that I used for that one was on the GFI though. These days electrical appliances are that safe that electrocution is hardly a hazard anymore. You will have to get into an appliance to come in touch with the electrical components.
Post# 1056742 , Reply# 21   1/6/2020 at 22:50 (1,570 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
This picture was taken in my bathroom. The shower corner is left from the AEG toploader. The bathroom was about 2 x 3 meters.
Post# 1056859 , Reply# 23   1/8/2020 at 10:31 (1,568 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
The grounded extension cord was plugged into an outlet on a GFI, so I didn't worry about that. I never used the AEG toploader while showering. BTW, it wasn't a trailing socket, just a regular double isolated extension cord that could only take one plug.
The frontloaders were on fixed bathroom connection with pull cord. |
Post# 1056871 , Reply# 24   1/8/2020 at 12:03 (1,568 days old) by Logixx (Germany)   |   | |
All I remember is how inconvenient I found it to have to blow dry my hair in my bedroom when I studied in the UK because there was no "proper" outlet in my en-suite bathroom. All the girls on my floor had extension cords so they could do their hair in front of the mirror.
And well, then there was this little thing about either washing your hands either under running ice water or steam. ;p |
