Thread Number: 81727  /  Tag: Vintage Automatic Washers
i have won a hotpoint 9530w on ebay
scroll >>> for more items
Post# 1057368   1/12/2020 at 12:02 (1,171 days old) by servis-dream (planet 90s, Hotpoint factory, Peterborough )
servis-dream's profile picture
i have finally done it
i have won a 9530 for £60.73 and i think the only damage is a right hand lid trim whick i can get off my 9544w and i could get this machine in the utility to replace a crappy candy 10kg washer
Post# 1057661 , Reply# 1   1/15/2020 at 14:08 (1,168 days old) by hippiedoll ( arizona )
CONGRATULATIONS!!
hippiedoll's profile picture
On getting a HOTPOINT frontloader!
Doing the HAPPY DANCE for you on this side of the computer...
:olD
I hope it's in as great condition as you are expecting! Keeping my fingers crossed that it is in PLUG & PLAY condition for you!
I'm not too familiar with frontload washers, other than the big ones I've used at the laundromat, to wash bulky things, maybe a handful of times, in my life.
Keep us posted & let us know how everything works out. I hope it's just needing that trim piece you mentioned!
:o)
Post# 1058043 , Reply# 2   1/18/2020 at 15:30 (1,164 days old) by servis-dream (planet 90s, Hotpoint factory, Peterborough )
it has all the trims as well
the hotpoint 95 series machines are almost 70's commercial machines that are down sized they are no nonsense timer driven monstars that in the 90's had the record for the fastest ever spin speed of 1400rpm (even though it was marketed ffor 1300rpm) this machine type pretty much ate carbon brushes, drum and motor bearings for tea with drum brackets for dessert
Post# 1058272 , Reply# 3   1/21/2020 at 09:00 (1,162 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)
Hotpoint New Generation
Congratulations Mathew on getting another British classic machine, not much you cant service n fix on these, I sold many in my time in the 80`s straight from the newest Hotpoint factory in Llandudno Juntion, North Wales..
Look forward to seeing the videos !!
Heres a few of my Classic Hotpoints..
Post# 1058273 , Reply# 4   1/21/2020 at 09:09 (1,162 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)
Hotpoint Laundry Appliances In The UK from start to New Gene
Heres an excellent thread that Paul (MatchboxPaul) made on the complete thread of Hotpoint UK Home Laundry Appliances from the first wringers in the 1930`s to the state of the art New Generation series built in a brand new factory which was EU funded, at the time it even rivalled all other manufacturers for the latest build technology using robots and computerisation.
CLICK HERE TO GO TO chestermikeuk's LINK
Post# 1058355 , Reply# 5   1/22/2020 at 06:32 (1,161 days old) by servis-dream (planet 90s, Hotpoint factory, Peterborough )
hey mike
i think that ransom spares still sell the lid trim kits for the 93, 95, 97 and 99 series machines. also i am switching the guts of a 4 way switch and a 5 way switch modifying them both to create another complete 4 way switch because the original one on my 9544w was broken during a shock absorber change from its worn ones to a set from my wm22w it had one stalk snap off entirely and one was left hanging on. i hope that i can do something about it but if not there is another 4 way switch on ebay for about £15
Post# 1062446 , Reply# 6   3/6/2020 at 08:25 (1,117 days old) by servis-dream (planet 90s, Hotpoint factory, Peterborough )
update
the 9530w is now being restored and professionally cleaned
the inner drum is absolutely perfect but a leg of the spider has snapped i think as the drum is very misaligned but other than that the machine is beautiful and will work in my house for a while as i am fed up with my candy GVS1410DC3 10kg washing machine that shakes the whole house
i am keeping the 4kg drum in the machine as it is original and will spin for another 32 years probably
another update is my 9544w will be returning after i fit a new heating element and make a new switch from parts
this is only 2 of 5 machines in my collection and i am only 15 years old, believe it or not i started collecting in may 2019 when i was 14
thanks
Matthew
Post# 1062456 , Reply# 7   3/6/2020 at 10:13 (1,117 days old) by vacerator (Macomb, Michigan)
Might this be the
washer from the "Shameless" telly series?
Post# 1062457 , Reply# 8   3/6/2020 at 10:14 (1,117 days old) by vacerator (Macomb, Michigan)
The one in
the council unit of the alchoholic father.
Post# 1062466 , Reply# 9   3/6/2020 at 10:36 (1,117 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Congrats on your find and acquisition
jetcone's profile picture
Nice looking machine and 1400 RPMS holy moly your clothes will be DONE!
Post# 1062483 , Reply# 10   3/6/2020 at 17:14 (1,116 days old) by eronie (Flushing Michigan)
I
Why did the older European machines use brushes in their motors?
Post# 1062523 , Reply# 11   3/7/2020 at 07:00 (1,116 days old) by gizmo (Victoria, Australia)
brush motors
Motor technology of the 1970s - induction motor or universal (brush type) motor. Induction motor, as used in USA top loaders, operates at a fixed speed (or possibly two fixed speeds if it has two windings inside).
The USA style two speed motor has two speeds that aren't hugely different - usually something like 3200 rpm and 1600 rpm. (Sorry if these numbers are a bit out - I'm Australian so more familiar with 50HZ supply, so our equivalent motors are 1440 rpm / 2880 rpm.) So a ratio of 2:1 between motor speeds. This is easy to achieve but useless in front loaders, where you require around 10:1 ratio between slow and fast motor speed - for wash speed the drum tumbles around 50 rpm, spin speed should be at least 500rpm at the drum. So many early front loaders had a mechanical transmission to give the two different drum speeds, but this adds weight, cost and complication.
A few lower priced European front load machines also used two speed induction motors, but a limitation of the technology means these machines had a miserably low spin speed, usually about 400 rpm. The two speed motors for Euro front loaders were huge and heavy, which took up space inside the cabinet. In their favour, they were simple and reliable. The two speeds (at the motor, not the drum) were 2880 fast speed (for spin) and about 360 rpm for Wash. this is a ratio of 8:1 so when the pulley sizes are engineered to give a wash tumble speed of 50 rpm, the spin will be 400 rpm. If you alter the gearing for a faster spin, the wash tumble will be too fast and the wash performance will be poor - the clothes will go round and round but never flop down in the tumble.
In the early 1980s some European machines had a variable diameter pulley on the motor, so when the motor stepped up to spin speed, the pulley diameter increased which got the spin up to a dazzling 800 rpm. These motors were huge, heavy and the variable diameter pulleys proved to be not very reliable.
The better performing alternative was to use a universal motor, which uses brushes. Like the motor in an electric drill. These are more compact, more efficient, and have infinitely variable speed with electronic control. So suddenly it became easy to design a washing machine that washes at 50rpm and spins at 1000 rpm or even more. This adds a cost in that you now need an electronic control module, and brushes wear down so you need brush replacements over time. In 1970s technology these are more noisy, too. (This improved over the years.) But the increase in performance is fantastic, and you can have improvements like the option of several spin speeds, and a special speed to balance the load before spinning, called Distribute. You can gradually ramp up the speed instead of jumping from wash to spin, so load balancing is easier and more effective. The motors can be much smaller, saving space (thus allowing a bigger drum) and weight.
Philips developed a similar technology using a permanent magnet motor, this still uses brushes but is even smaller and lighter, and can be more efficient, though Philips' early control circuitry was terribly inefficient, being designed more to reduce cost than save energy. they were very reliable, too. the Philips machines had infinitely variable spin speed, set by a simple dial, up to the max of about 1000 rpm.
Plenty of current front loaders use similar motors to these 1970s brush motors, though the electronics driving them is way more efficient now. I have recently acquired a Miele from about 2010 that still uses a brush motor, though it is very quiet, efficient and has varying speed wash tumble and very fast spin speeds. (1400 rpm drum speed on spin.)
the new technology these days is electronically controlled 3 phase motors (driving a 3 phase motor off a single phase supply using clever electronics) and brushless direct drive like F&P Smart Drive (which I think are also a different form of 3 phase, or perhaps brushless DC?) These are even more efficient, have an even greater range of speeds, don't have brushes to wear out, arc, get dusty and so on.
So that's why brushes.....
Chris.
