Thread Number: 81731
Late 1980’s filter flo set |
Post# 1057396   1/12/2020 at 18:52 (1,170 days old) by Repairguy (Danbury, Texas)   |   | |
![]() 2
I acquired this set between Christmas and New Years and just had a little time to tinker with the washer today. I replaced the agitator coupling as you could turn the agitator back and forth with your hand due to the rubber separating from the coupling. Cleaned it up a little and ran a few loads. Works great! It has a pinhole in the drain hose but other than that no leaks. I believe the pan and mini basket were probably with the machine, but I believe they were thrown away because the people that bought the house they were in did not know what they were. Thought I had a picture with the matching gas extra large capacity dryer but I guess not.
Washer model: WWA8354VLWH Serial: HA125369G |
Post# 1057401 , Reply# 1   1/12/2020 at 20:01 (1,170 days old) by jons1077 ![]() |
![]() 3
Post# 1057406 , Reply# 2   1/12/2020 at 21:07 (1,170 days old) by pulltostart ![]() |
Post# 1057408 , Reply# 3   1/12/2020 at 21:53 (1,170 days old) by combo52 ![]() |
![]() Hi Melvin and Jon, Yes I have never seen a MOL SS before, these were fun washers.
Melvin if you need the mini-basket for this washer I probably have an extra I could send, The SS MB is a little different as it does not have holes in the bottom of the MB, but I guess you could use a regular one and seal the holes in the Bottom?
Post# 1057466 , Reply# 4   1/13/2020 at 12:23 (1,169 days old) by Repairguy (Danbury, Texas)   |   | |
![]() 2
Thanks for the positive comments. Here’s some pictures of the matching extra large capacity gas dryer.
Model: DDG8189VTLWH Serial: MZ306966G |
Post# 1057487 , Reply# 5   1/13/2020 at 15:49 (1,169 days old) by goatfarmer ![]() |
![]() I forgot I had a Spotscrubber, this one looks a little closer to TOL.
Post# 1057497 , Reply# 6   1/13/2020 at 18:17 (1,169 days old) by combo52 ![]() |
![]() 2
![]() Hi Melvin, at first you got me excited thinking you had one of the 30" wide 8 CF dryers [ some of these even had a 30,000 BTU burner ] but alas this is just the 27" extra deep dryer.
I did not care for these extra deep GE dryers, because of having the heater box underneath they had a rear drum seal and a very sensitive safety thermostat so the heat cycled a lot unless you had a short and perfect vent run so you ended up with a slow dryer.
Post# 1057506 , Reply# 7   1/13/2020 at 19:55 (1,169 days old) by Repairguy (Danbury, Texas)   |   | |
Kenny, that’s a nice spot scrubber you have there. That’s the style I remember them being.
John, sorry to disappoint. I see the electric version of the dryer you speak of from time to time but I don’t think I’ve seen a gas one. I’ll keep my eyes peeled as now I want one. Were the 30” electric ones any good? I’ve worked on a few of those quite a few years ago now. Can you tell if one of these dryers is gas just by looking at the front of them? Was there an access panel? |
Post# 1057509 , Reply# 8   1/13/2020 at 20:57 (1,169 days old) by combo52 ![]() |
