Thread Number: 81935
Frigidaire FFTW1001PW TL Washer / FFRE1001PW0 Dryer |
Post# 1064097 , Reply# 2   3/22/2020 at 01:52 (1,489 days old) by niclonnic (Bonney Lake, WA)   |   | |
I just made a video demonstrating the wash action of this washer. The lid sensor is located under the left door hinge; I taped it in to bypass it. I also stuck a pair of scissors through the lid lock, and that's how I was able to make the washer run with the lid open. |
Post# 1064107 , Reply# 3   3/22/2020 at 05:39 (1,489 days old) by Yogitunes (New Jersey)   |   | |
Post# 1064232 , Reply# 4   3/23/2020 at 00:05 (1,488 days old) by niclonnic (Bonney Lake, WA)   |   | |
My water heater, which is a Rinnai RL75 tankless unit, is set at 120 degrees Fahrenheit. It's been at that setting ever since my family moved in. |
Post# 1064241 , Reply# 5   3/23/2020 at 03:29 (1,488 days old) by Yogitunes (New Jersey)   |   | |
first of all, your in a Northern state, your incoming cold water is really cold....
now starting with 120 degree hot water, which is a really warm bath temp....not exactly hot water to start with....the slightest dub down has turned all hot selections to warm at best... one advantage you have with the tankless, you can boost the temp while your washing clothes and then dial back down....140 to 160 would be best, and purge the lines if possible... theres concern for a water heater setting at 120 for the bacteria that can grow... on some machines we have taken out the restrictors, especially on the HOT side....and even turning down the cold water valve at the wall to help regulate the amount of cold water entering...other machines have programming we can't get around.. |
Post# 1064247 , Reply# 6   3/23/2020 at 05:46 (1,488 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
What kind of baths are you takeing? That's enough to poach salmon! |
Post# 1064250 , Reply# 7   3/23/2020 at 06:36 (1,488 days old) by DADoES (TX, U.S. of A.)   |   | |
160°F .... household stand-alone tankless water heaters (not tankless integrated into a boiler) are typically limited to maximum setting of 140°F. Mine was factory-limited to 125°F with a menu option to change the limit (to max of 140°F). Raising it to 140°F is unlikely to have much effect on this type of washer that dumbs down temperatures ... it will just mix in more cold water to maintain the programmed temperatures ... unless the user finds that a cycle other than Normal (perhaps Heavy Duty or Bedding) provides less restriction. Tankless is 100% flushed whenever water flows so is less likely to have the bacteria problem, and the heat exchanger surface gets considerably hotter than the output water temp. Mine is normally set at 102°F to 104°F for showering, although I raise it to various higher temps for clothes washing and *occasionally* for hand dishwashing, and *once in a while* so the first dishwasher fill is warmer for a particularly greasy load. I've not had any apparent trouble with bacteria accumulation in 15 years, on untreated well water. |
