Thread Number: 81982
/ Tag: Classified Ad Finds
Electronic Belt Drive WP |
Post# 1060062   2/9/2020 at 08:42 (1,529 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1060071 , Reply# 1   2/9/2020 at 10:20 (1,529 days old) by bajaespuma (Connecticut)   |   | |
Am I wrong or is it true that no Whirlpool TOL had a detergent dispenser the way TOL Lady Kenmores did. If so, was there some sort of contractual reason since Whirlpool made both? Or was the Whirlpool user supposed to use the agitator-mounted fabric softener dispenser for liquid detergent when using the Pre-wash cycle?
Post# 1060077 , Reply# 2   2/9/2020 at 11:31 (1,529 days old) by Yogitunes (New Jersey)   |   | |
the most you could get out of a Whirlpool having a detergent dispenser, was if it had the Magic Mix Dispenser Brush Filter.....
I dont think any Whirlpool had a Pre-Wash only cycle(maybe the Electronic machines did)......their cycle was labeled as a SuperWash.....which filled for wash, agitated for 4 minutes, partial drain, 4 min partial soak, and then added water to top off and continue on into the Normal cycle...at the start you would add a double dose of detergent... dont think we ever saw an 'extra rinse' option on Whirlpool or Kenmore...not until direct drives came out... |
Post# 1060085 , Reply# 3   2/9/2020 at 14:39 (1,529 days old) by DADoES (TX, U.S. of A.)   |   | |
These WP electronic belt-drive models varied on behavior for Super Wash. It can be used as a stand-alone prewash by selecting it (cold wash option) and Start without a Fabric cycle. Or as a traditional Super Wash by selecting Super Wash first, then a Fabric cycle, options, and Start (no detergent dispenser so add a double-dose of detergent at the start). The user guide for an early model says stand-alone selection stops after the partial drain, leaving the remaining water. The user is advised to run a Spin Only to drain it, then run a full cycle of choice. I suppose a full cycle could be run directly without draining first. A later model runs a full drain and spin in stand-alone Super Wash/prewash mode. A following direct-drive model has separate choices for both Super Wash and Prewash (and Soak). Soak is only a stand-alone soak, drains & spins ... then the user runs the desired full cycle. |
Post# 1060135 , Reply# 4   2/10/2020 at 07:57 (1,528 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1060178 , Reply# 5   2/10/2020 at 16:50 (1,528 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1060185 , Reply# 6   2/10/2020 at 17:09 (1,528 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1060202 , Reply# 8   2/10/2020 at 19:24 (1,528 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1060826 , Reply# 10   2/17/2020 at 17:05 (1,521 days old) by stricklybojack (South Hams Devon UK)   |   | |
Post# 1060828 , Reply# 11   2/17/2020 at 17:19 (1,521 days old) by DADoES (TX, U.S. of A.)   |   | |
